Hello there
I´m trying to learn how to connect the InDesign with a web page for a future project.
Now I´m using the sample code released for Adobe at the JavaScript Tools Guide, but all my tries was unsuccessful.
I cold not connect with any page, server and bla, bla, bla.
Check the below code (exactly as in Adobe reference document)
reply = "";
conn = new Socket;
// access Adobe’s home page
if (conn.open ("www.adobe.com:80")) {
// send a HTTP GET request
conn.write ("GET /index.html HTTP/1.0\n\n");
// and read the server’s reply
reply = conn.read(999999);
conn.close();
Anyone can help me?
PS.: I´ve read a lot of topcs, articles and tutorials about this subject and all my tests was unsucessful.
Hello,
Try this snippet (not working with "www.adobe.com")
var conn = new Socket;
var host = "www.indesignjs.de";
var cmd = "GET /index.html HTTP/1.1\r\nHost:"+host+"\r\n\r\n";
var reply='';
conn.timeout = 100;
if (conn.open (host +':80', 'BINARY')) {
conn.write (cmd);
while (conn.connected && ! conn.eof) {
reply += conn.read(1024) + "\n";
conn.close();
alert(reply);
Good luck 😉
I could never get it to myself to work neither but I think I read other fellows around did so it's likely you should find some snippets already in the forum.
FWIW, the only times i had to retrieve data from http,I used getUrl from Rorohiko, it works like a charm:
HTH
Loic
Dear Loic.Aigon
First of all, thanks for your attention.
I've seen before a lot of designners/programmers getting successful tests with this snnipet code that you mentioned. I think if I try, I will also could.
I wish do something with the Socket object, but if I couldn´t I will use the Rorohiko tools.
Thanks a lot
Hi Vinicius,
see also this thread where several methods are discussed:
Is it possible to load web content?
FWIW and it might not apply in your case:
For downloading e.g. an image from a dropbox account I had success with a combined AppleScript/ExtendScript method using curl services that are implemented with OSX.
Uwe
Hello,
var reply='';
conn.timeout = 100;
conn.write (cmd);
conn.close();
alert(reply);
Good luck 😉
Hello Ronald
I´ve tryed to use your code, but the variable returns me nothing.
Have you returned anything?
When I check the connection, it retuns me false
It is an official document from Adobe.
I can´t believe it not will gonna work.
I get a reply ... (Testing with MacOS 10.12.3 - InDesign CC2014).
If you are on Windows, maybe a problem with the anti-virus or firewall.
I can confirm what Ronald says.
I'm on Mac OSX using InDesign CC 2017 and ran the script snippet from the ESTK.
It returned:
HTTP/1.1 200 OK
Date: Sat, 04 Mar 2017 13:00:35 GMT
Server: Apache/2.4.18 (Ubuntu)
Last-Modified: Thu, 30 Jul 2015 11:55:00 GMT
ETag: "e3-51c165f764d00"
Accept-Ranges: bytes
Content-Length: 227
Vary: Accept-Encoding
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html><head><meta http-equiv=Refresh content="0;url=/auflage2/"></head>
<body>
<a href="auflage2/index.php">2. Auflage InDesign automatisieren</a>
</body>
</html>
Seems the file is by Gregor Fellenz.
Uwe
Perfect Laubender
Now I have a new task...
Why it is not working on my PC.
I will get an other internet link and try it again.
Thanks for your attention.
Hi Ronald
Thanks for your help.
I also have one Mac and it is working,
Now I have to figure out why is not working on PC in my companny.
I don't think it is because a possible firewall.
I will keep in contact.
Hi Laubender
I just need to access a TXT or XML file.
I believe the Rorohiko solution works fine, but I wanna know why the Adobe´s solution doesn´t.
If I could not fix this issue I will use the Rorohiko.
Best regards
