quote:
Originally posted by: Captiv8r
Hi all
Hopefully Colum will pardon my intrusion into the thread. I believe the expressions that are created are added to the ProjectName.PSS file. One easy way to get at this is to right-click any topic, choose Topic Properties, then the File tab. Now click the Open Folder button. Bingo! You are now in the general area. If your topic is inside a folder, you may need to navigate up the tree once or twice to the root of it. There you should find the PSS file.
Edit the PSS file using Windows Notepad. My expressions were added at the bottom of the file.
Cheers all... Rick
quote:
Originally posted by: Colum McAndrew
Hi Robin. You seem to be referring to the cross hatch that appears over text that has a build tag applied to it. Right? You can amend the colour of this cross hatch to be the same as your background. Go into your build tag folder and edit the properties.
