I just updated my Lightroom CC to the latest 2015.8 release. It was working OK previously except for needing closed and restarted every hour due to slow downs. Anyway, I now have an annoying issue in that when I go into the develop module and I go through adjusting my images and flagging those I dont like as rejected, I then "Delete rejected Photos".
Once that is done, the develop module work space where the image appears is set to the preview of the last image that was rejected.
After this, no matter which images I click in the image bar below, or even if I click out to Library then back in to Develop, the last rejected image (despite having been deleted) is still shown. It does not change to any other image until I close Lightroom and restart it.
I am running on Windows 10, not tried in Mac OSX yet. Is anyone else having this issue and have you found a fix for it at all?
Ken.
Please add your me-too vote and details of your issue to this bug report in the official Adobe feedback forum: Lightroom: No Image displays in Develop Module after Deletion of Other Images | Photoshop Family Customer Community . (This forum is primarily a user-to-user forum in which Adobe product developers rarely participate.) Be sure to copy and paste the results of Help > System Info. This will make it a little more likely Adobe will fix the issue.
This has been reported here a few times.
Please make a post of it here.
Photoshop Lightroom | Photoshop Family Customer Community
The work around is to go back to the library module before you delete the rejected images. You can do that easily by hitting the g key.
I just tried this on my Mac and it worked as expected. Does it do this EVERY time or is it a random behavior?
Posted in these threads.
Bug? Main image display becomes blank/frozen after deleting an image in library
And something similar.
Lightroom Develop shows wrong image
Seems to be a Win 10 problem as it doesn't happen on Win 7.
Thanks for the info
its not just a Win 10 problem buddy. I have it happening on Mac Sierra
when i press X to flag photos as rejected and then do a Command+Delete to delete them all i get errors "An error occured when attempting to change modules" and everything is blank and i cant click on Library, develop or anything. I also get the problem where it freezes on one image and even clicking on different images does nothing to change it. Broken POS program for at least the past year. HORRIBLE.
It works fine on El Capitan so must be a Sierra issue. Adobe should fix it but Apple OS is getting buggier also and Apple seems to break things in every new release.
Please add your me-too vote and details of your issue to this bug report in the official Adobe feedback forum: Lightroom: No Image displays in Develop Module after Deletion of Other Images | Photoshop Family Cus... . (This forum is primarily a user-to-user forum in which Adobe product developers rarely participate.) Be sure to copy and paste the results of Help > System Info. This will make it a little more likely Adobe will fix the issue.
Same thing is happening to me. iMac with El Capitan.
Same problem with Win 7
I don't have this problem. Win 7 Pro LR CC 2015.8. But then I don't use the GPU feature (In fact the newest updates have actually disable that option where as before I could enable it. Now I can't.).
Either right click and select Remove Photo then Delete from Disk display goes to next image. Hitting the delete key does the same.
So if you are having this problem on a win 7 system then it is specific to your system setup. Try disabling the GPU option.
Thanks for info guys.
Hi there,
This issue has been acknowledged. Please find more info here: Lightroom: No Image displays in Develop Module after Deletion of Other Images | Photoshop Family Cus...
The current workaround is to go back to the Library Module before you delete the rejected images. You can do that easily by hitting the G key. Others have reported that reinstalling the app also solves the issue. Please try that and let us know if the issue still occurs.
Melissa
Have this exact issue on Mac (macOS Sierra 10.12.2):
Hi kennetho,
Please update Lightroom to 6.9/2015.9 version which includes the fix for Lightroom: No Image displays in Develop Module after Deletion of Other Images | Photoshop Family Cus...
refer: Lightroom CC 2015.9 now available
Mohit
