Hyphenation exception ignored
Mar 08, 2017 Mar 08, 2017
I'm experiencing a very strange behaviour in InDesign CC 2017.
I have a special word inside a footnote which is hyphenated wrongly. Therefore I have put the word in the user dictionary. I've tried two variants, first with correct hyphenation points, and second without any. Unfortunately ID is ignoring both and insist on the program's decision how to hyphenate.
What can I do?
Best regards,
Ulrich
1.4K
Explorer , Mar 08, 2017 Mar 08, 2017
I have solved the problem! When I set in preferences the option under user dictionary "Benutzerwörterbuch in Dokument einlesen" ("read user dictionary in document" my bad translation 😉 it actually applied all entries in user dictionary. Otherwise it seems to ignore it and only uses decisions made in the document ...
Hyphenation exceptions are set per language. Check if you added it to the right language dictionary (or, alternatively, check if your footnote text has the right language applied).
See Spell-check and language dictionaries in InDesign
I have checked the language setting ("Deutsch: 2006 Rechtschreibreform") in the footnote paragraph style ("Fußnotentext"), and it is the same which I have in my preferences ("Deutsch: 2006 Rechtschreibreform"). I have looked in /Users/uli/Library/Application Support/Adobe/Linguistics/UserDictionaries/Adobe Custom Dictionary/de_DE (the path which is shown in preferences) and the word actually is in the file added.txt.
Any further idea?
you should check what paragraph style is applied to your footnote text and adjust (or turn off) the hyphenation settings.
Select the text with your text cursor, open your Paragraph style panel and right click on the highlighted style to Edit it. Check the settings in the Hyphenation section.
If this is not helping, please add in your comment more details, for example, how did you set the formatting of your text.
Regards
Mentor ,
And in case nothing of the above won't work for some reason, you always have a backdoor workaround: apply No Break to that word. I'd include a regex in a footnote ParaStyle for this.
Yes, this is a work-around. But honestly InDesign should do this correctly -- if it wasn't my fault.
Contributor ,
Apr 07, 2017 Apr 07, 2017
As I have a similar problem, I found your thread. I suppose the correct English translation in the preferences is "Merge User Dictionary into Document".
