Resize image pix without loosing quality
Mar 08, 2017 Mar 08, 2017
Hello!
I have an image 1400 by 1400 pix and want to resize it to match 450 height and 750 width to put it on a website. I tried image size > changed the height to 450, and then added some white space left and right. The image was then the correct size of 450 h 750 w, but I lost the quality and it looks blurry.
Is there any way to reduce image size without loosing quality?
Thanks a lot!
Anna
445
Community Expert , Mar 08, 2017 Mar 08, 2017
Image > Image Size, (ensure the measurement is pixels) tick Resample, and from the drop-down menu select Bicubic Sharper.
Adobe
When you change the aspect ratio of an image you have basically three choices: crop part of the image, stretch the image or have letterboxing.
If you reduce the image size it shouldn't normally reduce the quality.
Thank you. But for some reason it does, so I dont know what I do wrong. Im new to photoshop so if you happen to know where it goes wrong, would you specifically tell me which menu options to choose?
When you go from 1400 pixels wide to 750 pixels wide, you throw out half the information, so in that sense there is obviously a quality loss.
But more to the point, resampling always softens an image. Sharp edges turn slightly fuzzy, that's inevitable. Standard procedure is therefore to carefully sharpen after resampling. It doesn't necessarily take much, just enough to rebuild the edges and transitions.
Photoshop's resampling algorithms have some sharpening built in. "Bicubic" has a little, "Bicubic smoother" very little, and "Bicubic sharper" quite a lot. But for best results you should do it manually and visually at 100% view.
Which brings up another point. Resampling also happens to the on-screen display, when you view at any other zoom ratio than 100%. So to critically evaluate sharpness, you must view at 100%. This maps one image pixel to exactly one screen pixel, and is the only entirely accurate view.
