*New anim clip extension* for Animate CC 2017 ?
Feb 08, 2017 Feb 08, 2017
I used to work with 'new anim clip' extension from http://www.toonmonkey.com/extensions.html.
On their website they do have a cc version (zxp file). However, the extension manager of Animate 2017 doesn't let me install it.
Please someone help about it. This is an important issue for a lot of animate users around the world. It is directly concerning for saving time and hence also money.
I really can't see any reasonable cause for not enabling this plugin to work. Thanks a lot in advance.
2.0K
Contributor , Feb 08, 2017 Feb 08, 2017
Try using NewerAnimClip.zxp - works on CC 2017 for me.
write to toonmonkey.
Contributor ,
Mar 07, 2017 Mar 07, 2017
I get "This extension can not be installed, it requires Flash version 8 or greater." Not sure if 24.0.0.221 is "Flash 8". I think it's more to do with the .zxp extension than anything else.
Mar 08, 2017 Mar 08, 2017
You need to download Adobe Extension Manager CS6, convert older .mxp extensions to .zxp (or use the one provided in a few threads back)
Then install the .zxp extension using a Mac Utility.  This guy details it here: Adobe Animate Installing Flash Extensions MXP/ZXP - YouTube  But he doesn't show where to get that Mac Utility that does the trick.
If you were lucky enough to have that extension when you had CS6, you may have kept it during your upgrades, which I assume why it works from some people. If you're starting fresh, a new computer with fresh installs of CC, you'll have to go through the steps.  From what I'm finding, Adobe hasn't supported Extension Manager recently...?
Perhaps the next update, they'll have a "nesting" command built in. *hint hint*
Contributor ,
Jan 10, 2018 Jan 10, 2018
It seems to not work in the newest version of Animate.
Also, I accidentally removed the file I linked to in my answer. For anyone wants to try it, you can download it here: NewerAnimClip.zxp
The file Travis linked to will hopefully solve the problem, but if not, see this article on how to install ZXP files:
https://helpx.adobe.com/animate/kb/install-animate-extensions.html
If the link Colin gave you doesn't work you could also try this utility to install extensions. Works great for me...
ZXPInstaller
