I have over 52 mins of 3840x2160 pixels video made in front of Green Background. Currently I am using After Effects multiple features for removing the Green background. But when I import this After Effect project in Premiere Pro CC for editing (giving various backgrounds) then the System becomes very slow - almost unworkable. I am using 27 inch IMac with 4 Ghz core i7 processor, 32 GB Ram @ 1600 MHz DDR3 & 1 TB SSD.
I have also tried first making an alpha video by rendering this AE project in Premiere Pro in 3840x2160 pixels by using Animation option for rendering. Although I am able to edit this alpha channel file in Premiere Pro but the problems are multiple.
a) Renderning 52 minutes of 3840x2160 pixels AE project in Premiere Pro takes more than 35 hours.
b) It alpha file requires huge huge space on my SSD.
Is there a better & efficent way of doing it?
I will be really obliged for kind assistance.
Qamar
52 minutes!!!
I'd cut that up into just the shots you are going to use so you don't waste any time working on or rendering frames that you are not going to work on.
Unless your composite requires advanced features you only have assess to in After Effects I would do the keying in Premiere Pro. I would never ever try and dynamically link an AE project (comp) that was longer than a few seconds because:
Not really. You get what you ask for. You can try image sequences of course and depending on the image content, e.g. LZW-compressed TIFFs might end up producing very small files, but otherwise there's not realyl much you can do other than buying bigger nad faster drives.
Mylenium
Indeed there is! First, determine your delivery specifications. Do you really need to deliver video in those large dimensions? If you do not, you can work in the smaller HD.
Next, Your workflow is backwards. You edit first and THEN do the effects. AE's strength lies in creating shots, not in creating program-length shots for use when editing later. You'll probably cut out some of that footage. You're not including the backgrounds, which you should be doing if you're working in AE. You're making HUGE alpha-channeled files, some of which you won't even use! You're wasting render time. You're wasting storage space. It's inefficient.
Edit your project. Then chroma key. There is a perfectly-good chroma keyer in Premiere Pro that you should probably use.
There might be a cheap (in terms of file size) way out for you if you render out 2 sequences of high quality JPEGs from After Effects - 1 for the main video, and 1 for the alpha channel (just a black and white image sequence). Then you have a small-ish sequence that you can key out in Premiere using the black and white sequence as a matte. This is not a recommended workflow.
Like Dave said though, edit first, then key.
52 minutes!!!
I hope this helps. Premiere Pro's Keyers will do at least as good a job if not a much better job as the keying you see on your local weather report in much less time than AE. The only reason to use AE is to do something that can't be done in Premiere Pro or your NLE of choice.
