Estoy haciendo una página web traducido a 7 idiomas, leí en internet que la mejor opción era hacer cada página individualmente y ya las tengo en sus respectivas carpetas. También tengo un menú de selección de idioma igual en cada página, pero no logro hacer la vinculación correctamente entre idiomas.
También leí que se puede hacer una pagina de inicio con selección de idioma y al dar clic te lleva a dicho idioma, pero ya en navegación, si se quisiera cambiar de idioma tendría que regresar a la página de inicio? o se puede hacer el cambio de idioma desde el menú que ya tengo preparado?.
Gracias
If your site is huge then it might prove a little difficult in managing the site.
So in such case, you can either opt for choosing a good translate widget for yourself available here - translate – Adobe Muse Widget Directory
Hope this helps.
Ankush
Hi emmgzz,
Not the exact answer to your question, but this forum post should provide you with some insights into what you are looking for.
How can i create a multilingual website?
Preran
So i have to use only one Muse file which will have seven master pages (each one with a different language) and eleven pages for each master page. And then i can link every language button to their page?
I'm confused.
Hope this helps.
Ankush
You have to make 7 separate sites (7 muse files) and uploud them in 7 folders on the hosting, re-link with absolute links. In general, of course, this work is not for the Muse. You or your customer will go crazy when you administer this site. There is a little guile in how the Muse is positioned. In practice, Muse is a program for developing web design, but not for developing a website. Feel the difference. . In order to do what you want, you need a CMS.
I think. adobe needs a little more honest positioning Muse, that would not mislead users. Very offensive and difficult situation, when the user spent a three-month on the creation of a site of 100 pages, and in the end it turned out that such a site is not possible to manage.
