Get installation error ("Application Initialization Error") when trying to install Flash Player 24.0.0221
[Moved from non-technical Lounge Forum to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
Hi d30817
What operating system is this on and what is the name of the installer file you are using?
Maria
Windows 10.
Although I gave you the error message, I have attached a picture of those words.
Here is the installer
I'll need to get the installation log files from you to troubleshoot the 'application initialization error'. Please provide the following log files:
Upload the files to cloud.acrobat.com/send using the instructions at How to share a document​. Post the link to the uploaded files in your reply.
As an alternative, you can try using the offline installer posted at the bottom of the Installation problems | Flash Player | Windows 7 and earlier page in the 'Still having problems' section, however, without the installation log files we can't troubleshoot why the initialization error is occurring.
Thank you.
Maria
Hi d30817 ,
Thank you for providing the log files. The Initialization error is being returned because the certificate, for the installer, cannot be verified:
03/08/17 17:08:41:659 | [INFO] | | ADM | | ApplicationContext | | | 10680 | GetIEProxyInfo - Failed to get proxy for the url, error:12180
03/08/17 17:08:42:264 | [WARN] | | ADM | | ApplicationContext | HTTPSend | | 10680 | Certificate not matching.
03/08/17 17:08:42:264 | [FATAL] | | ADM | | WorkflowManager | HTTPConnectorError | | 10680 | Error occurred while getting application xml: -4 extended error: 0
03/08/17 17:08:44:445 | [ERROR] | | ADM | | ApplicationContext | IPCCommunications | | 5768 | Error CB_PktID_Terminate
Do you use a proxy server, or a network traffic monitor software such as Wireshark or Charles Proxy?
Maria
No, I do not use a proxy server. How do I fix the certificate issue?
I will forward the log files and information to the online installer team. In the interim, can you please post a screenshot of your systems Local Area Network (LAN) Settings window?
Control Panel > Internet Options > Connections tab > LAN Settings
Thank you.
Maria
Hi d30817
Thank you very much. I'll forward this information to the online installer team. In the mean time you can use the offline installer I link to in my second reply.
Maria
I didn't see the second message with the offline installer link
