I recently upgraded my Lightroom 4 perpetual license to Lightroom 6 via download. The initial download resulted in Version 6.0 only. Nevertheless everything seemed intact including all the develop presets (both colour and B&W) included in Lightroom 4. However, when I updated to Version 6.9 the colour presets disappeared and I can't find them anywhere. When I go to Preferences, the Lightroom Presets folder within Develop Presets shows empty despite only the Colour Presets being missing in the side panel on Lightroom. I note that other members of this forum have had similar problems but not quite the same as mine (e.g. all their Develop Presets have disappeared not just Colour Presets).
A solution to my particular problem would be appreciated, noting I'm only semi computer literate.
Adobe CC downloaded a Lightroom update on my PC yesterday (2015.9), and after the upgrade, the "Lightroom Color Presets" dropdown was missing. However, I found all of the built-in Color Presets hiding under the "Lightroom B&W Filter Presets" dropdown, alongside the B&W presets that I've always had. In the screenshot below, anything that doesn't have the word "Filter" in the name is actually a Color Preset which used to be under a separate dropdown. Check to see if you find yours in the same plac
...Copy link to clipboard
I haven't noticed if I am missing built-in develop presets from the upgrade to 2015.9 as i ignore most of them but this is what I have. I wish the others would disappear or the user could get rid of them. I don't want to be forced to have them cluttering up my preset menu.
Yes, I have the same it's only the Colour Preset which is missing. I don't use them a great deal myself but they can be useful for a quick and dirty develop. My main concern is that features disappear without any notice/explanation. What else has gone that I haven't noticed yet?
At some time in version upgrades the default 'inbuilt' LR presets provided by Adobe changed from being visible and able to be copied in the Dev Presets folder, to being 'hard-wired' into the software program (and not possible to delete!). It is possible that the Colour Presets disappeared with that change.
Is it worth experimenting by re-installing Lr4 to see if the missing Colour Presets re-appear, and can be copied and saved with the OS for use with Lr6?
I still have a list of 27 presets that I do not remember where they came from!
Thanks a lot! You appear to be right about the Dev Presets "being 'hard-wired' into the software program". However. mikeg2112 has revealed that the Colour Presets are now included under the Lightroom B&W Filter Presets (see above).
Adobe CC downloaded a Lightroom update on my PC yesterday (2015.9), and after the upgrade, the "Lightroom Color Presets" dropdown was missing. However, I found all of the built-in Color Presets hiding under the "Lightroom B&W Filter Presets" dropdown, alongside the B&W presets that I've always had. In the screenshot below, anything that doesn't have the word "Filter" in the name is actually a Color Preset which used to be under a separate dropdown. Check to see if you find yours in the same place.
Thank you very much, the mystery has been solved! The Colour Presets are indeed now mixed in with the B&W Filter Presets (I never dreamt to look for them there). Unfortunately, although they can be copied to a new folder, they can't be deleted from the "hard-wired" folder. This something Adobe could look at.
I'm guessing that was an error on Adobe's part in this latest upgrade, since there's no reason why those Color Presets should be in the "B&W Filter" group. Like you, I thought they just disappeared, and then I started looking inside of all of the dropdowns to see if anything else had changed.
This is funny, I just realize too, since I used this color preset a lot with my LR Mobile.
JSJ
Adobe has acknowledged this bug in 2015.9 / 6.9 and says it will be fixed in an upcoming update: Re: Color presets moved after update
My presets are also missing, but they are not mixed in under any other section as mentioned here. I have also tried the checking and then unhecking the store with catalog option, and nothing changed. All of my presets are gone, and i have been using them in every catalog for years. I don't know where to find them all again, and Adobe seems to only have this forum to get help, so I am hoping someone can help.
You will find a lot of info at this link that may provide clues- and see the page links at the base of the lenscraft article also.
https://lenscraft.co.uk/tutorial-organizing-lightroom-presets/
https://www.lightroomqueen.com/articles-page/lightroom-cc6-default-locations/
