I know, this is an Adobe forum but... Adobe has removed server behaviours and killed InterAKT (Developer Toolbox) so I think that it's still a topic that could interests many DW's users.
WordPress is a great tool but I think that develop a website without a "ready to use" CMS is still the best way, the best web workflow (especially for corporate websites).
What do you think?
Other DW users share my thoughts?
I would have liked to put this message on the DMXzone forum, but isn't available a section "general".
While I basically agree with your narrative, just a few points
1. WebAssist do have their MySQLi extension which is very similar to the deprecated SB panel.
2. DMXZone extensions are a bit hard to get one's head around, but there is a new development using App Connect. This is a new concept where the data sources are manipulated by the client application (browser). In turn this makes the framework a lot simpler to understand, but more importantly, makes it a lot faster. The queries are created se
...Copy link to clipboard
2. DMXZone extensions are a bit hard to get one's head around, but there is a new development using App Connect. This is a new concept where the data sources are manipulated by the client application (browser). In turn this makes the framework a lot simpler to understand, but more importantly, makes it a lot faster. The queries are created serverside, the manipulation of those queries is client side. This makes it easier to filter queries as well as only show the results if the query contains data.
3. I totally share your view of the DMXZone forum.
4. There are many extensions and it is hard to know which ones to install (purchase). They do offer complete Collections to make the choices easier as can be seen from the following image
To show if there is data
On the server side, using Server Connect, you can Insert, Edit or Delete data, easier than in the days of ADDT.
The main problem is to be able to grasp the concept.
Disclaimer: I have no connection/relation with DMXZone or Webassist, I am merely a user of their products.
Hi Ben,
thank you for your opinions!
FYI, at the moment with the last App Connect, to show a dynamic section only if a recordset isn't empty, is possible only changing manually the code.
These are the instructions received from the DMXzone tech support:
Select your div, then dynamic attributes > show.
For the expression, select serverconnect.data.query and just add length to it so it becomes:
serverconnect1.data.query1.length
The problem is that when I need to update the code, I need every time to remember the modification customised.
I'm using DW to simplify the work and I need to have a panel (as the old server behaviour) that showing me all the behaviours in the page otherwise all becomes complicated (much better to work manually on the code, without extensions).
Yes, I have had to do some hand coding as well. But this is because the likes of the Data Formatter has not been released. Actually, I don't mind a bit of hand coding when I can do it faster than having to go through the steps.
Edit:
As you can see from the screenshot, I have tackled the empty data slightly differently, comparing the the ID from the detail region with that of the ID in the 2nd table that I want to show the relevant records for. No ID from the detail area, no show of results. If there is an ID in the detail area, then filter the results to that ID
I've a question for you Ben...
Do you have a solution about the problem with local/remote db server?
I set my site up with two testing servers, one local and one to my remote server. When I enter the details for the remote, I switch to the remote testing server and enter the details in the Connection Options. When that is done, I revert to the local testing server and change the details to the local server. This needs to be done once per site.
Perfect, thanks!
I hope to see very soon from DMXzone a solution "definitive" also for this.
OT: Why Adobe not give money to DMXzone to build new server behaviours integrated on the new version of Dreamweaver (late 2018)?
We might have a better product and the new behaviours could be used also from the others extension developers (as a standard).
Hello Ben,
do you have problems with IE 11 bowser to visualise the data generate from DMXzone App Connect?
On Edge is ok, on IE 11 (and also for Windows Phone App) not loaded nothing:
UPDATE: DMXzone confimed the issue and will release a fix in the next days.
Wow, I had not thought of testing with IE, but none of my sites work in IE (3% usage). Will ask DMXZone about this.
Edit:
I hope you do not mind if I use your example because mine are all in a password protected area.
Edit Edit:
Thanks, I see that you have already told them.
Issue (IE browser compatibility) fixed in the last 1.0.6 version (launched today).
Hi Ben,
please could you tell me if you have error messages in the browser's panel inspection about missing dmxzone .map files?
Just to figure out if I lost something while uploading files to the server.
No I don't. Could you show me a screen shot?
I've opened this request for assistance on DMXzone (see the screenshot):
I've received an answer from Teodor.
No .map files in the DMXzone's extensions (considered unnecessary).
My only advice would be to become more familar with the coding an extension produces if you are going to use one.
Very often, once you have seen the pattern of coding, its easier to just do some of the more simple operations like creating a 'Show if' region directly within the code rather than use an UI.
The extension will create a php variable with the number of records found allocate to it, then its a matter of testing the variable to see if its empty 0 or it contains something:
<?php if($count == 0) { ?>
<h1>Sorry no records could be found</h1>
<?php } else { ?>
<h1>Records found</h1>
<?php } ?>
You could even set up a template (snippet) which will surround the code you want to show, if DW does that. I know other programs do. Then it becomes even simpler - select code, choose template.
Speaking of dmxzone what is this: http://wappler.io/​ ? It's logo says "by dmxZone" ? I couldn't find anything related to this on their website. Is it legit or this some other company?
Wappler - The Visual Web App Creator
This makes me believe that DMXzone are in the process of giving us an alternative to Dreamweaver.
Yes, the code has been written in typical DMXzone style.
BenPleysier wrote
Wappler - The Visual Web App CreatorThis makes me believe that DMXzone are in the process of giving us an alternative to Dreamweaver.
All i can say is that it would be an interesting development if Theo is going to give us a Dw alternative.
On second thoughts, it may be an extension for Dreamweaver. To me it seems an huge task to create an alternative to Dreamweaver.
Maybe it's only the extension "DMXzone Webpack Builder" listed in the roadmap 2017 (see "DMXzone Building and Packaging Tools" section):
DMXzone Bootstrap 4 Visual Designer for App Connect
You are right!
BenPleysier wrote
DMXzone Bootstrap 4 Visual Designer for App ConnectYou are right!
Well he did allude to something forthcoming shortly in a previous forum thread about Bootstrap shortly after V4 was launched.....since a great deal of their extensions are Bootstrap based and DW is way behind the curve as are most of the other apps out there are, like Bootstrap Studio and Bootstrap Builder........was not difficult to put 2 and 2 together which makes 5, doesn't it?
Thing is there are a lot of app developers out there, most die on their ass and lack any real teeth after a couple of years of development and the app eventually falls in a state of hibernation and become useless to those that have bought into it. To be a serious app developer you have to be committed and in it for the long run, DMXzone are one of those few app and extension developers that are commited.
I contacted them in their support chat but the only thing they confirmed was that this is not going to be an extension. The support guy told me, that he cannot share anything else at this point. Hm...
Well those that are interested had better hope it does not follow Bootstrap 4s timeline of testing and bringing to market, that took about 2 years or was it 3, I lost count.
Not really.
If they base it on the Brackets editor, (which is open source anyway) and add their server behaviours plus a few other extensions, (e.g. Bootstrap and sass) complete with say the Brackets ftp extension, then all that would be required is a decent file management system and they would have a viable alternative to Dw.
Even starting from scratch and just using Brackets or similar as a starting point, it is not as large a task as one would think. If you look at the size of the actual Dw engineering team, (forget everyone else) then it is not that much bigger than DMX's team, and lets be honest if they teamed-up with people like Al and his team from Project Seven to make it compatible with their extensions also, I honestly think they would be on a winner.
The problem with Dw, (and most other paid for web tools) is that it only offers the file management tools over programs that are available for free, especially for those developing server side and wanting some form of visual interface.
That all said, until I see or hear something from Theo, I'm not taking is too serious.
