I have many tables in my file, is there any script which can help me to apply below properties ignore font and its font family,
my procedure will be i will select the whole single table and i will click the script and below properties will be applied...
font size 7 and leading 8
and cell properties
and row hieght
Thanks in advance!!!
You wrote: "font size 7 and leading 8". So I thought you wanted to apply only these values.
Anyway, in JavaScript it is quite easy to make modifications by intuition -- even for those who are unfamiliar with coding.
Here's another version. You can select either the whole table, or one or more cells
Also, in this version you can Undo-Redo the whole script.
...var scriptName = "Table",
doc;
app.doScript(PreCheck, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "\"" + scriptName + "\" script"
Let's try this script. Place the cursor into the table an run it.
doc;
PreCheck();
//===================================== FUNCTIONS ======================================
function Main() {
var table = CatchTable();
table.cells.everyItem().texts[0].pointSize = "7 pt";
table.cells.everyItem().texts[0].leading = "8 pt";
table.cells.everyItem().leftInset = table.cells.everyItem().rightInset = "1 mm";
table.cells.everyItem().topInset = table.cells.everyItem().bottomInset = "0.5 mm";
table.cells.everyItem().verticalJustification = VerticalJustification.CENTER_ALIGN;
table.cells.everyItem().autoGrow = true;
table.cells.everyItem().minimumHeight = "3.75 mm";
function CatchTable() {
if (app.selection.length > 0) {
if (app.selection[0].parent.constructor.name == "Table") {
return app.selection[0].parent;
else if (app.selection[0].parent.parent.constructor.name == "Table") {
return app.selection[0].parent.parent;
else {
ErrorExit("Place the cursor into the table.", true);
} else {
function PreCheck() {
if (app.documents.length == 0) ErrorExit("Please open a document and try again.", true);
doc = app.activeDocument;
if (doc.converted) ErrorExit("The current document has been modified by being converted from older version of InDesign. Please save the document and try again.", true);
if (!doc.saved) ErrorExit("The current document has not been saved since it was created. Please save the document and try again.", true);
Main();
function ErrorExit(error, icon) {
alert(error, scriptName, icon);
exit();
Hope it helps!
— Kas
Thank u very much!!! it works u help me lot with this script, there is only one problem, which i have mentioned below, can u please solve this by modifying the same script...
Thanks in Advance
I have modified the script to adjust kerning and tracking value, and it works but it was not possible without ur script!!! thanks again...
modified script
table.cells.everyItem().texts[0].tracking = 0;
table.cells.everyItem().texts[0].kerningValue = 0;
I got 1 problem, can I apply this script to selected cells, because there is one row which I don't want these properties to be applied it as to be left as it is ...
Thanks in advance
doc;
app.doScript(PreCheck, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "\"" + scriptName + "\" script");
function Main() {
if (app.selection[0].constructor.name == "Table") {
var cells = app.selection[0].cells.everyItem().getElements();
for (var i = 0; i < cells.length; i++) {
ProcessCell(cells);
else {
ProcessCell(app.selection[0]);
function ProcessCell(cell) {
cell.texts[0].pointSize = "7 pt";
cell.texts[0].leading = "8 pt";
cell.texts[0].tracking = 0;
cell.texts[0].kerningValue = 0;
cell.leftInset = cell.rightInset = "1 mm";
cell.topInset = cell.bottomInset = "0.5 mm";
cell.verticalJustification = VerticalJustification.CENTER_ALIGN;
cell.autoGrow = true;
cell.minimumHeight = "3.75 mm";
if (app.selection.length == 0) ErrorExit("Nothing is selected, Select some cells and try again.", true);
if (app.selection[0].constructor.name != "Cell" && app.selection[0].constructor.name != "Table") ErrorExit("Select a table, or one or more cells and try again.", true);
Main();
exit();
— Kas
hello, thanks for your script, but when I select complete table i.e all rows and columns the all above properties get applied but when I select particular 5 cells or a single row of 6 cells the properties get applied to only first cell ( font size and line spacing do not get change after second cell )
Hi there,
The script assumes that only a table should be selected. I don't remember why I did it since it was a couple of months ago.
Modify the line #8 like so:
if (app.selection[0].constructor.name == "Table" || app.selection[0].constructor.name == "Cell") {
This way it will work with selected cells as well.
— Kas
thanks it woks,
can you please add more commands in scripts to keep value as per above highlighted...
ie vertical and horizontal scale as "100", baseline shift and character rotation as "0"
I would do it with Table and Cell Styles, not with a script.
I cant create additional styles in my file because it is against policy of my project
