I have problem on latest muse upgrade: I can't fix the object (like menu on top) on the page. Doesn't work!
Ok, I solved the problem. In the iPhone breakpoint I have used a different plugin menu that disabled the normal pin.
Thank you
Which element are you talking about? Could you be a little bit more specific?
Yes, you already told us and it’s clear to see. But why don’t you give us additional informations?
• Which element do you want to pin?
• Is it part of another element (for example: a trigger of a composition?)
• How is it configured?
• Is it a footer element?
Ok,
It is a normal menù created with standard menu of muse option on the top of the page.
It is not a part of other element.
I have also tried to pin a simple rectangle but it does't work
Can’t believe!
Create new site, place one of these "unpinnable" elements, upload this .muse file to Dropbox or a similar file sharing service and provide the download link here. Then we can have a closer look.
Thus, time consuming „question and answer“ games or pure guessing can be considerably reduced.
Thank you
don't pin in phone layouts mate... as a rule they don't like that
