Hi All,
We using this vb code to launch InDesign CC2015 in widows7.
Set myInDesign = CreateObject("InDesign.Application.CC2015")
Msgbox("This message from Vbscript")
myJavaScript = "D:\Program Files (x86)\Adobe\Adobe InDesign CC 2015\Scripts\Scripts Panel\Test.jsx"
Msgbox("This message from Vbscript-Script")
myInDesign.DoScript myJavaScript, 1246973031
But we are getting the below error message while run the Vbscript.
Help me to suggest better way..
Thanks in Advance,
Mahesh
I can't say that's the issue but backslashes can be escaping characters so once interpreted it can be read as
"D:*rogram Files (x86)*dobeAdobe InDesign CC 2015*cripts*cripts PanelTest.jsx"
* means any interpretation of escape the following character.
Use this instead:
D:\\Program Files (x86)\\Adobe\\Adobe InDesign CC 2015\\Scripts\\Scripts Panel\\Test.jsx"
In clear english, escape the escaping character…
Loic
Hi Loic,
The escaping here is not the issue, (The codes in VB and not js) \ doesn't need escaping in the visual basic family.
In fact escaping it would cause problems.
Regarding the Op's problem see
Re: InDesign CS6 scripts don't work on CC anymore
and
Re: Create Indesign.Application CC
HTH
Trevor
this is not VB.
Your code is VB, it creates a String of the file name.
then using DoScript.javascript you are passing the string to the Javascript engine.
Escape them as stated by Loic.Aigon​
"D:\\Program Files (x86)\\Adobe\\Adobe InDesign CC 2015\\Scripts\\Scripts Panel\\Test.jsx"
or revers them
"D:/Program Files (x86)/Adobe/Adobe InDesign CC 2015/Scripts/Scripts Panel/Test.jsx"
both will work.
also:
should be
Set myInDesign = CreateObject("InDesign.Application.CC.2015")
Sorry Loic,
I should of spotted the "myJavaScript, 1246973031" part.
Trevor
Nope, I'm not sorry.
I just tested it. In this case the myJavaScript is not javascript it is the path to the javascript so it need not be escaped.
However escaping it does not cause harm neither does using / instead of \.
In summary all 3 methods work here.
Trevor
Hi All,
Thanks for reply. I tried all possibilities but the error comes as follows. I am new to VB script. help me.
My task is in windows system to execute InDesign javascript file in script panel from outside of the InDesign as applescript does as below.
But the applescript not execute in windows system so I tried in VB script.
AppleScript code
set aScriptPath to "Applications:Adobe InDesign CC 2015:Scripts:Scripts Panel:Test:Test.jsxbin"
set pScriptPath to POSIX path of aScriptPath --"/Applications/Adobe InDesign CC 2015/Scripts/Scripts Panel/Test/Test.jsxbin"
tell application "Adobe InDesign CS6"
Activate
do script alias aScriptPath language javascript
end tell
Please help me.
Thanks in Advance,
Mahesh
Hi there,
Here's a working example:
Set myInDesign = CreateObject("InDesign.Application.CC.2017")
myJavaScript = "C:\Program Files\Adobe\Adobe InDesign CC 2017\Scripts\Scripts Panel\Test.jsxbin"
myInDesign.DoScript myJavaScript, idScriptLanguage.idJavascript
Also, you can reference the application without specifying the version like so:
Set myInDesign = CreateObject("InDesign.Application")
The JavaScript is the one-liner:
alert("Hello from JavaScript", "JavaScript message", false);
I get it called from VBS:
Hope this helps.
— Kas
My turn to say sorry,
I miss read and saw DoScript.javascript, not DoScript myJavaScript.
Here's a more elegant solution: both scripts should be located in the same folder -- JS and VBS. The latter uses the ActiveScript property to figure out the path to the folder with the scripts.
Set myFSO = CreateObject("Scripting.FileSystemObject")
myActiveScript = myInDesign.ActiveScript
Set myFile = myFSO.GetFile(myActiveScript)
myJavaScriptFileName = "Test.jsxbin"
myJavaScriptFilePath = myFile.ParentFolder.Path & "\" & myJavaScriptFileName
myInDesign.DoScript myJavaScriptFilePath , idScriptLanguage.idJavascript
Looks like there's something wrong with the path Mahesh is using.
Try
pathToMyFile = "C:\Path\to\the\file" ' change to the correct path
Msgbox("VB says - File exists: " & CreateObject("Scripting.FileSystemObject").FileExists(pathToMyFile))
CreateObject("InDesign.Application.CC.2015").DoScript "alert(""Hi From InDesign"")", 1246973031
If the path is false then you know your problems nothing to do with ID
If you get "Hi From InDesign" then you know you are communicating good with ID
If the problems with the path then try with a more simple path like "C:\myJavaScript.jsx" and see if that works.
HTH
Trevor
Did you not get this working?
