I have a book contains 66 documents in which i want to find words which are incorrect and change it using the FindChangeByList.jsx sample script. But it crashes with error.
i am using this Change scripts to run through multiple documents in a book, rather than just the open document to load my Book but crashes with this error message pasted below
the code i used to run FindChangeByList is :
main();
exit();
function main() {
var myBook = app.open(File("C:\\Users\\sony.zacharia\\Desktop\\BCS\\Bible.indb")), myDoc;
$.writeln(myBook.name)
var myDocs = myBook.bookContents.everyItem().getElements();
for (var i=0; i< myDocs.length; i++) {
// must be adapted to your needs
myDoc = app.open(File("C:\\Users\\sony.zacharia\\Desktop\\BCS\\" + myDocs.name));
$.writeln (myDoc.name)
var myFile = new File ("C:\\Program Files\\Adobe\\Adobe InDesign CC 2017\\Scripts\\Scripts Panel\\Samples\\JavaScript\\FindChangeByList.jsx");
$.writeln (myFile.name)
if (myFile.exists) {
app.doScript(myFile, ScriptLanguage.JAVASCRIPT);
myDoc.close();
Please help me to sort this issue. Thanks in advance!
thank you so much @tpk1982 for your help! Actually the txt file i has had a list of words around 2600 words and i tried it using 160 words at a time and it worked. Feeling relieved that i have to only use script few number of times than actually finding and replacing the words. huh!
Two things..
1) Avoid using $.writeln()... because it will open the extendscript application unnecessarily.. just delete or comment it
2) Why the path contains double slashes? ( var myFile = new File ("C:\\Program Files\\Adobe\\Adobe InDesign CC 2017\\Scripts\\Scripts Panel\\Samples\\JavaScript\\FindChangeByList.jsx"); )
1) i will change all the occurrence written for console. 2) i found out using double slash \\ from some discussion as single slash was not read for path
Double slashes using for searching anything in grep search.. not for path.. i hope
You can use the single slash is enough
one more remark when i run FindChangeByScript.jsx in one single document then also the same Error:25 is coming up. š
app.doScript(myFile, ScriptLanguage.JAVASCRIPT); i think the problem is with this line. Am i using it correctly? I am a beginner in indesign. Don't have any experience with this kind of work. š
I mostly used doScript for calling internal functions.. but yes we can call the script.. i hope the other experts in this forum will guide you..
But the below thread will help you.. is it you posted a part of script or entire one?
Re: User-defined Objects as Arguments to app.doScript()
Code to be evaluated! [016] Tabs Position! ā¦
Suppress dialog when executing jsxbin file from app.doscript
