Editing Text in a Scanned Document
Nov 29, 2016 Nov 29, 2016
   I am trying to edit scanned text in Adobe Acrobat Standard DC. I am not able to do so unless I convert to a Word file format. The purpose is to copy and paste text out of the PDF.  I am able to do this on a Adobe Acrobat Pro DC program but not Standard. Is this limited to just Pro? According to the Adobe Acrobat Tutorials it should work for both. There is nothing that specifies whether it is Acrobat Standard or Pro, just as long as it is not Reader.  Below is a screenshot showing the "Edit PDF" Menu on the right from Standard not showing the text option. Below that is the screenshot from PRO where it appears.
Acrobat Standard
Acrobat PRO
Is this a setting that is set up in PRO automatically that I am missing in Standard? I looked all over to find the differences between the 2 and can't seem to find it so that I can add this to my Edit Menu. I need to be able to edit scanned documents without converting them to Word in order to save time. Having to convert back and forth is a time drain.
Edit and convert PDFs
2.9K
Adobe Employee ,
Dec 14, 2016 Dec 14, 2016
Hi kathyn7691112​,
Editing of scanned documents is a PRO only feature. This feature is not available in Adobe Acrobat Standard and Reader.
Priyanka
Dec 15, 2016 Dec 15, 2016
In Acrobat Standard you must first use Tools > Enhance Scans
Mar 10, 2017 Mar 10, 2017
Bernd Alheit, sure that works? It doesnt work with my DC standard. Look like only Pro can do this! No?
Editing Text directly in pdfs is only available in Pro, no way to do it in the DC Version
Adobe Support says:
Enhance Scans is available
OCR with Enhance Scans doesn´t solve the original Problem: Editing Text
Did you read the replies?
Yes. Did you understand the Problem?
Yes. I answered the question about Enhance Scans in Acrobat Standard,
There are a number of differences when it comes to recognizing text between Acrobat DC Standard and Pro. Some of these differences also depend on the version of Standard or Pro you are running (perpetual license - or "classic" - versus the subscription - or continuous - version).
Acrobat Pro in it's continuous version will automatically OCR a document when you try to edit it, and will create a version that allows you to actually edit text. Acrobat Standard will not do this, and even if you run OCR manually (via the "enhance scans" function) will never create a document that can be edited - all it does is store the recognized text "behind" the original image.
You mention in your question that you only need this to copy and paste text from the PDF document into a different document - if that different document is not a PDF file, you can do this with Standard: Just run OCR via the "Enhance Scans" tools, and then select text, copy and paste e.g. into a MS Word document. For anything else, you will need Acrobat Pro.
Karl Heinz Kremer​ You said, that there are differences between the versions of DC Pro, do you know, that all versions allowing to edit the text direct in pdf or is there any version, which is not able to do this?! I am going to buy a DC Pro Version, but want to be sure, that this essential function is includet..
The difference is between the classic and the continuous version of Acrobat DC Pro: With the classic version, you get only those features that were implemented at the time the application was originally released, all you get in the updates are security updates and bug fixes, The continuous (or subscription) version gets updates to it's functionality (in addition to bug fixes and security updates) every three months. You can find out what was added since Acrobat DC was originally released here: https://helpx.adobe.com/acrobat/using/whats-new.html - there are links to the previous updates at the bottom of the page.
When it comes to OCR, the only differences I am aware of are an update to the OCR engine, updates to OCR'ing camera images, and the automatic OCR when you try to edit a scanned document. You can of course still invoke OCR manually. In all versions of Acrobat DC Pro, you can create documents in the "Editable Text&Images" format:
