I am not seeing the Lightroom 2015.9 update in Creative Cloud. It updated to the latest version of Camera Raw (9.9) but Lightroom is still on 2015.8. I have tried signing out a few times, checking for updates and even re-installing Creative Cloud. No luck. Could anybody please help?
samirkilachand wrote
Ok, so uninstalled LR CC 2015.8. Restarted my Mac and re-installed to 2015.9.
No.
Yes uninstall 2015.8, and do that from the CC DTA, and then reinstall it from the CC DTA.
Go to the following webpage and click on Lightroom 6. You will see the updates. The Lightroom CC 2015.9 update is the same installer as for Lightroom 6 .9. Just download the installer and run it.
Hi, I downloaded the 2015.9 update and tried to install it. It says the Adobe Application manager may be damaged. When I click on the link in the dialog box it takes me to the Creative Cloud Desktop app. I have tried re-installing it but same problem. I tried downloading the full Lightroom 6 package but when I click on install it says installer failed to initialize there may be a file missing.
Any suggestions?
Jim has you pointed in a good direction.
Alternatively, if you sign out and back in using the CC Desktop app, this usually gets the updates properly loaded if they were not done before.
No.
Thats what I meant to say. Did that from CC DTA and it worked. I have 2015.9 and its retained all my settings.
There should be no need to uninstall LR CC 2015.8, just run the update application. The update is a patch it is not the full application.
If you uninstall then you have to first install LR CC 2015 then the update to 2015.9.
I tried this over 5 times and did not work for me. Had to uninstall and reinstall via the Creative Cloud Desktop App. First time this has happened to me. Have been using LR for the past 5 years.
I've tried several times uninstalling through the DTA, then reinstalling and it only installs the first version, but doesn't mention a need to update?
I was running 2015.8 but had the same issue as the OP
After uninstalling, reboot. Then sign out of the CC DTA. Sign back in. It should find the latest LR update. Try re-installing. This worked for me. Alternatively, as mentioned you can directly download the 2015.9 update from the website
