I am needing to remove password encryption for 100s of files via batch processing, and I require the generation of a report displaying results of the success or failure of each file of the processed batch. (The detail of the report is necessary in case the passwords are not the same, e.g. case sensitivity).
I've tried Action Wizard>Password Security>Remove Encryption function, but the resulting log report does not indicate pass/fail. (app: Adobe Acrobat PRO v10 and 11)
Any information is greatly appreciated. Thanks!
Did you enable the log option under Edit - Preferences - Action Wizard?
thank you
Just had the time to try it, and the result is the same - the log didn't identify failed instances. Thanks.
In that case it probably can't be done.
On Fri, Mar 10, 2017 at 7:19 PM, googletodreamweaver <
