Hey guys and gals!
First time posting - 'cause I'm simply getting frustrated.
So in Photoshop I'll start getting wobbly lines after a few minutes of work. After a bit of trial and error, I realized that going into the display settings and moving one of the monitors (not physically) a little and apply it - I'd not longer have wobbly lines in Photoshop. Though the problem would show itself again after a few minutes of work. So that's my (hopefully) temporary solution that doesn't really fix the problem.
Things I've done to try and fix the problem:
I know that maybe to other people it wobble doesn't seem glaringly apparent - but trust me when I say it's definitely there!
This is severely messing with my work flow - as a professional artist, this is torture! Please help. I've added a photo, video, and computer specs below.
Link to system specs:
https://justpaste.it/14ch8
Smooth lines on left, wobbly lines on right.
Video of the problem and my temp solution:
Thanks everyone.
WinTab definitely tends to give better results than Windows Ink with Windows 8.1 and 10, but if you use your Cintiq to draw, then Lazy Nezumi Pro is a total no brainer. In fact I have just amazed myself after trying to make the swirl below with and without LNP turned on, and discovering how shite I was without LNP
Hi
When you tried turning off windows ink, did you try creating and adding the PSUserConfig.txt as per the details in this page (under "For other tablets") ? :
Tablet support for Photoshop on Windows 8
It says Windows 8 and Photoshop cc2015 but is still worth trying with Windows 10 and Photoshop CC2017
Dave
Hey Dave, thanks for replying.
I did yes, didn't help unfortunately.
Hey Trevor,
I downloaded Lazy Nezumi Pro about a week ago with no results - the problem keeps showing up unfortunately. Thank you for your input though! Appreciate you taking the time to help.
Alright, so apparently I was using Lazy Nezumi Pro incorrectly to solve my problem. To fix the wobbly lines:
(Open Lazy Nezumi Pro --> Settings --> Edit Photoshop Settings --> Fix jitter bug)
Thank you Trevor.
This did the trick for me!!!
Oh my gosh, thank you all!!!! I have been wrestling with this problem off and on for MONTHS, and had tried everything I could find on the internet. I have used Lazy Nezumi for quite a while, but I had never seen that particular checkbox. I clicked it, and VOILA!!! No more wobbly lines!!! I'm so happy!
Thank you thank you thank you!!!!!
