I saved an after effects project cc 2017, closed the project, and closed the program, which at the time of closing caught a little; I turned off the computer and went to sleep.
On the other day the project presented this error, and more those listed below:
"Host_IO, ReloadFile flaiure" (114)
Can not find source item for layer ID = 133; A placeholder will be used to replace. (26 :: 143)
Your project file is apparently corrupted (ignored sections: 2). Save with different name. (26 :: 0)
After I click on "ok" which is the only option it has, it opens, but from an earlier period of the project, and with a name extension (converted), and I have to redo everything again.
Note: I hung up after giving the error I proceeded with the project, saved it with a different name and closed the program, and turned off the computer; The problem persisted. 2 TIMES!!
Without knowing anything about the specifics of the project, nobody can tell you much. Obviously if a specific source file goes missing, then its format and other technical parameters are relevant as are any effects and operations you may have applied. In any case, start by flushing your caches.
Mylenium
Hi Mylenium, how i can tell you much more about that project?
How can I make a "diagnosis" of the project with more technical data?
See this page.
