3
Audio does not play after paused?
Mar 10, 2017 Mar 10, 2017
okay, so basically the audio is in a separate layer than the animation and working just fine, but when i pause the audio and play it again, the audio is silent. i put it on loop and everytime the audio starts over it works again. this is very annoying because i need to know the exact location of where the singing of the song begins. is there anyway to fix this? id appreciate any help given, thank you!
16.5K
LEGEND , Mar 10, 2017 Mar 10, 2017
Select the sound in the timeline, then in Properties set the Sync to be Stream instead of Event.
If you are creating an animation to go to video you should use an ActionScript 3.0 FLA, not an HTML5 Canvas FLA. With an AS3 FLA you can set the sound's sync to Stream instead of Event, and then you can start the sound playing from any point.
If you're making an animation that has to play back in HTML5, still use an AS3 FLA with Stream sync, at least until you have finished animating in time with the sound. After that you can convert the animation to HTML5 Canvas, and hopefully the animation will keep up with the sound.
Can you say more about what you're doing, before I tell you about other things that can go wrong (and how to fix them)?
well, jeez. didnt fully understand the first part, aha, but i created a new file as a actionscript file and there is the same problem.
here is a screen shot if that helps ^^
Mar 11, 2017 Mar 11, 2017
thank you both! it worked ^^
Mar 14, 2021 Mar 14, 2021
i love u
Sep 26, 2022 Sep 26, 2022
I know I'm late to the thread, but I'm having the same problem. However, I don't see a Sync option anywhere in Properties. Is there something I'm missing?
Sep 01, 2023 Sep 01, 2023
but when I go to properties it doesn;t show me steam neither even. btw im working on adobe animate 2019
Adobe Employee ,
When you click on a keyframe or a frame in a layer, you will get the properties window with different sections like, Sound, Label, color effects etc. Under Sound, you can see the word Sync with dropdown option to select between stream and event.
Sep 02, 2023 Sep 02, 2023
Thank you for your answer but still when I press right-click on a frame or keyframe in the layer that has audio, it does show options like insert keyframe, actions, etc. But I don't see a properties option, neither stream nor event
Sorry now I get it thank you for the response now i see the option
stream and event are the two main sync properties
i have one more question. sometimes when i press f6 it takes me back to the first frame and it is very fustrating, how do i solve it
you can customize most animate shortcuts (including f6) by clicking edit>keyboard shortcuts.
f6 is a timeline shortcut, so expand timeline and remove f6 or change what it does (by re-assigning it) by clicking it and choosing an option
You click on the orange bit (audio) and on the right side in PROPERTIES, it should say SYNC somewhere. Press the thing that should probably say EVENT and then change it to STREAM.
May 08, 2020 May 08, 2020
Definitely helped! Thank you very much!
