from photoshop back to lightroom?
Mar 11, 2017 Mar 11, 2017
Hi.  If someone has the answer to my problem, I would be so appreciative.  All along, I "command e" from lightroom to photoshop and then "save" in photoshop when I am finished and my image saves back into lightroom in a TIFF file... until yesterday.  I don't know where the saved file from photoshop goes but it does not go back into LR.  This is a major interruption to my workflow and quite frustrating.  Any help for a desperate photog??? Please
21.7K
Are you in a collection when you are sending images to PS? Images aren't auto placed in a collection when going back into LR when saved in PS.
If you start from a collection, the saved tiff will get saved back into the same collection. This is my preferred workflow, because it is easy to find the tiff in LR when I return. This even works if you save the file as a PSD to some other location of your drive, and give it a new name. It didn't always work this way, but thankfully that got fixed.
If you return to Lightroom and do not see the .tif it will likely be as JSM has suggested. If you have exported to Photoshop from within a collection you will need to synchronize the original file folder to have the edited file added to that folder. From within your collection, right click to 'Go to folder in Library', select that folder in the left column, right click and Synchronize. It will be added to the folder. You may want to add it to your collection at that point.
Mar 12, 2017 Mar 12, 2017
"I don't know where the saved file from photoshop goes but it does not go back into LR.  This is a major interruption to my workflow and quite frustrating."
When you select an image to 'Edit in Photoshop' (CMD E) then save and return to Lightroom, the edited file is being saved to the original folder that the image is in in  your catalog. It should also show up in your collection. If you don't see it when you go back to Lightroom, check to see what your 'Sort' is on and change it to 'added order' or 'capture time'.
Nov 18, 2018 Nov 18, 2018
Agreed: this is frustrating.  The replies keep mentioning "catalogues" and "collections" but I -for one- am in Lightroom CC (as opposed to Lightroom Classic CC ...which used to be called Lightroom CC, right?) which uses terms like "folder" and "album" - and so I, too, would like a solution to this very same issue.  Thank you.
This forum is for LR Classic (the traditional desktop-focused LR). If you repost in the LR CC forum (for the cloud-focused LR), you'll get better help faster: Lightroom CC — The cloud-based photo service
Since PS would give you a TIFF file upon PS save or close, I assume you started with a RAW file in LR? Or did you actually select to edit in PS as a copy?
Anyhow, in LR, ion the folder the initial image is in, did you try a SYNC? (for the folder)?
Also, while your issue is different from the prevailing issue of grayed out menu items in PS when doing an edit in from LR (if PS is not running when you hit that edit in button, or other edits sent to PS from LR), test the work around for that known bug. Start PS before you send the image over to PS from LR.
Nov 11, 2019 Nov 11, 2019
I don't know if you have your answer, yet, but I've found I have to save and CLOSE in PS for it to roundtrip back to LR.
Dec 11, 2022 Dec 11, 2022
This should be higher up - this is the actual problem in Lightroom CC and Photoshop CC.
  1.  Open in Photoshop
  2. Make edits
  3. Save
  4. Close file in PS
  5. Lightroom will show '2' next to the thumbnail of the image to show that there are two versions
Dec 12, 2022 Dec 12, 2022
Thank You!
Sent from my iPhone
Jan 03, 2023 Jan 03, 2023
Hi there, I'm fairly new to LRc but been struggling with this problem for a few days and it wasn't always the case! Maybe a new iMac and new versions have created the same problem as above? I do what i always did, LRc to edit in PS but now the  PS edited version (2) does not show up in the LRc catalogue collection, but in the original folder on my external drive instead! As an added bonus, I am no longer able to create virtual copies and for them to appear in the film strip. Are these two issues connected? Any suggestions very gratefully received. Thanks, Neil in UK
Hi Russell, Your experience is not mine  (in Lr-Classic 9 and Ps2020 -Windows)
I can send a file from Lr to Ps by [Ctrl+E]
'Save' the new Ps file (do not Close)- it appears in Lr, (afer this 'first' Save)
Keep editing the file still remaining in Ps, 'Save' again- and the preview/photo in Lr is updated to the new Ps edit.
I can do this repeatedly (without ever 'Closing' the photo in Ps) - each Ps save updates the file in Lr.
Same as above. Send file to PS from LR, press Ctrl + s to save it as a new TIF file it immediately shows up in LR Classic.
The RAF file sent to PS. Time stamp is File name.
Then I did a Ctrl + s. Again time stamp is file name.
Jan 24, 2021 Jan 24, 2021
I am having the same problem. I am not in a collection - just my photos. Has always worked fine until today.
Jan 25, 2021 Jan 25, 2021
I am having the same problem. I have Lightroom cc. My LR image  is not in a collection. I am not able to press File> save to get the image back to LR.
Sometimes  'Save ' is grayed out and sometimes it is active but the image is not saved . Ths is very frustrating.
 HELP!!!
Apr 08, 2022 Apr 08, 2022
I have lightroom classic LrC.  I just save it in Photoshop and it transfers the photo automaticaly back to LrC as a second photo next to the original.
This looks like an old post... there must have been an upgrade.
Happy Editing
