How do i make break a big chunk of text into several paragraphs?
Do i use enter or shift enter? Whats the difference?
Enter begins a new paragraph.
Shift + Enter is a line break.
Paragraph formatting is attached to a paragraph, so it does make a difference, especially if you have a first line indent, alignment, space above or below, etc.
HTH!
HTH!
One other question: Does high quality or press quality preset retain my transparencies?
Unrelated questions are best asked in a separate thread because other people search, but the key here is that Acrobat 4 does not support transparency. Acrobat 5 and later does. Both of those presets are set to Acrobat 5 by default, so you are good!
Using the PDF Export presets of either High Quality Print or Press Quality should retain the transparency.
