I have Premiere Elements 12. I have loaded a dvd with miscellaneous different videos that I want to split out and separate into different files, and edit in the process. I can do the editing and clipping but can't seem to find any way to save the separate videos. Publish+Share just seems to save everything into one massive file again. I don't see the point of that.
I have seen similar questions asked from several years ago but the answers do not answer this very simple question which I repeat.
I can highlight a section of split video but I can't seem to save that highlighted piece on it's own. This seems so trivially simple that I apologize in advance if it is dumb newbie question.
Set the work area bar on the timeline in expert mode only over the part you want to save separately and then export it.
Thanks, although unfortunately I haven't advanced to Expert yet. Under Quick the selected clip is clear. When going to Expert I don't even know what I am looking at let alone where "export" is. I guess I need to find more tutorials or is this as simple as I imagine it should be. If it's not to much trouble, please advise some appropriate menu commands to point me in the righ direction.
Export is "share." Same animal, different name.
I've never used Quick and don't have Premiere Elements installed now.
This may help you with the work area bar:
WAB - Work Area Bar - What's That?
Some general help:
OK, that helps a bit although the Muvipix link needs a subscription, but I did now see that on my file dropdown menu Export is grayed out and a number of options are not there for me. The demo was for 13 and I have 12, but does this mean I haven't registered this or something else? I've had the, legal, package a few years but only recently tried to use it.
Those particular downloads are free, but you do have to register on the site, much like you have to register here, because there is also a free forum.
I am not sure, but I think that version 13 is similar to version 12.
