Add ink stroke to multiple shapes/objects
Mar 12, 2017 Mar 12, 2017
Is there a way to add an ink stroke to a bunch of shapes/objects at once instead of having to click every part manually? I'm referring to shapes/objects that do not already have an ink outlines.
650
Adobe Employee , Mar 13, 2017 Mar 13, 2017
The following JSFL should work if you have selected the shapes already:
fl.getDocumentDOM().selection[0].x+=0; //this line does not have any effect but seems to be required.
fl.getDocumentDOM().setStrokeSize(1);
You can save the JSFL file as a command and assign a keyboard shortcut to it for quick access.
you can use jsfl for that, but i don't know a way to do that from the animate interface.
Does JSFL have access to multiple islands in a selected shape?
yes, jsfl can loop through each and every shape/object and apply a stroke of various kinds.
I don't think so, but using the Ink Bottle tool is quite quick. How many shapes to you want to give a stroke?
The "I don't think so" was in reply to the original post, not the JSFL idea. My posts arrived out of order!
Really? I find that hard to believe. Oh well. I've already manually applied the stroke to all the objects. It took a while. Also, what is JSFL??
Adobe Employee ,
I tested that and it does work. This time I'll mark Nipun's answer as Correct!
I gave kglad a 'helpful' too.
Can someone explain to me what a JSFL is? I'm not familiar with it.
it's a language that lets you run code in the authoring environment, http://help.adobe.com/en_US/flash/cs/extend/flash_cs5_extending.pdf
Adobe Employee ,
Mar 14, 2017 Mar 14, 2017
All you need to do is go to File Menu > New > choose JSFL Script File > OK
Copy paste the below code and save the file:
Now, simply go back to your Fla document, choose all the shapes you want to add stroke to, goto Commands menu and click on the file name you saved above.
It can be even easier than that. Copy and paste Nipun's code into a new JSFL document. Select the shapes on the stage, and above the JSFL document there is a play button. Click that. No need to save the JSFL or add it to your commands menu.
Of course, if you're going to be doing a lot of the same action it's handy to have it in the commands menu.
