вот код, в формате javascript :
var mask = new createjs.Shape();
mask._off = true;
mask.graphics
.p("AEMCVIgHgEIgGgFQgCgEAAgDIACgHIADgFIAGgEIAHgBIAIABIAKAFIAHABQAFAAADgDIAHgHIAFgIIAPggIhPiQIAjAAIA7BsIAwhsIAQAAIhOCyQgFALgGAIQgHAIgHAGQgHAFgHADQgIACgHAAgAh8CQIAAjXIAeAAIAAAfIAKgMIANgLQAGgFAJgDQAIgDAKAAQANAAALAFQALAGAGAKQAIAKAEANQAEANAAAPQAAARgFAQQgFAQgJALQgIAMgOAGQgOAHgRAAIgMgBIgKgCIgKgDIgJgFIAABIgAhBg0IgLAGIgKAIIgIAJIAABDQAAAHADAGQADAHAFAEQAGAFAHACQAIADAJAAQAIAAAIgEQAHgFAGgIQAFgIAEgLQADgLAAgNQAAgPgDgNQgDgNgFgIQgGgIgHgFQgHgEgJAAQgHAAgGACgACCBQQgIgDgFgFQgFgFgDgHQgCgHAAgIQAAgKAEgIQAEgIAGgGQAHgGAJgFIATgHIAqgMIAAgKQAAgKgCgHQgCgIgEgEQgEgEgFgCQgGgCgGAAQgIAAgFACQgFACgCADQgDADgBAFIgCAQIgCAGIgFAFQgDABgEAAIgHgBIgFgEIgDgFIgBgIQAAgHAFgHQAFgGAIgFQAIgFAMgCQALgDAMAAQAPAAALADQAKADAHAFQAGAFADAIQADAHAAAJIAAByIgfAAIAAgVIgWAQQgGAEgHACQgHACgKAAQgJAAgHgDgACrACIgNAHIgLAIIgHAJQgDAFAAAGQAAAFACAGQACAFAEADQADAEAFACQAEADAFAAIAKgCIAJgDIARgMIAAg3gAj+BNQgOgGgKgKQgKgKgGgNQgGgOAAgPQAAgQAFgQQAGgQAKgLQAJgLAOgHQAOgGARAAQAPAAANAFQAMAFAJAJQAJAJAFAMQAFALAAANIhyAAQAAAOAEANQAEANAHAJQAHAKAKAFQAKAGAMAAQAKAAAJgDQAJgEAIgFQAHgFAFgHQAFgHADgHIAIAEQgDAMgHAKQgIALgJAHQgKAIgMAFQgLAEgMAAQgQAAgNgGgAjDgWQAAgJgDgHQgDgIgFgFQgGgGgHgDQgHgDgIAAQgHAAgGADQgHADgFAGQgFAFgDAIQgDAHgBAJIBMAAIAAAAgAAxBQIAAjdIAWgIIAIAAIAADlgAmZBQIAAiXIAeAAIAAAdIAJgNIALgKIALgHQAGgCAGAAIAKABIAHAEIAFAGQACADAAAEQAAAHgEAEQgFAEgIAAIgJgBIgKgFIgHgBIgGACIgGAFIgGAHIgGAKIAABog");
mask.setTransform(75, 55);
вот в чём загвоздка, не пойму, какой шифр здесь. именно этот длинный код:
который означает "replay"
Пример работы кода :http://jsfiddle.net/ogzr3y5v/8/
может у кого нибудь есть генератор такова шифра или статьи по этой теме
Cпaсибо большое за внимание !
If you create a new HTML5 Canvas FLA, and use the brush tool to draw a new shape, then publish that, in the .js file you will see the decodePath string. I tried it by drawing a blob and replacing your jsfiddle example with the code from my blob. It worked well, and drew several copies of my blob. Here the data I used (watch out for any spaces, they should be removed):
AgdGuIgWgDIgKgCIgKgCIgKgDIgLgDIgRgEIgPgIIgNgHIgMgIIgKgIIgMgHIgLgHIgMgIIgKgHIgMgIIgLgIIgMgHIgKgHIgPgIIgMgHIgKgIIgIgIIgFgHIgFgHIgIgI
...Copy link to clipboard
Yes, the Canvas publishing from Animate produces Text as vector shapes when you use Static Text in your project.
If you change the text field type to Dynamic text, it is published as editable text itself.
Know more about it here: Create HTML5 Canvas documents in Animate CC | Static Vs Dynamic Text
I unmarked Nipun's message as being correct because the topic has nothing to do with text. The example graphic mask just happens to look like a word.
nikog, see this page, it converts images to Base64, which is what I think the code is:
By the way, I may end up being wrong, I couldn't convert the code back into an image. I'm checking what other format it might be.
Ok, I'm on the right lines now! The code is a decodePath, which is I think Base64 encoded coordinates to draw the shape. I didn't find an encoder yet, except one from Google that is used in their maps. Anyway, read about decodeaPath here:
....eventually no longer a generator so text?
AgdGuIgWgDIgKgCIgKgCIgKgDIgLgDIgRgEIgPgIIgNgHIgMgIIgKgIIgMgHIgLgHIgMgIIgKgHIgMgIIgLgIIgMgHIgKgHIgPgIIgMgHIgKgIIgIgIIgFgHIgFgHIgIgIIgFgHIgEgIIgIgIIgFgHIgHgHIgGgIIgEgHIgGgIIgHgIIgFgHIgFgHIgIgIIgEgHIgGgIIgEgIIgIgHIgFgHIgCgIIgGgHIgCgIIgCgIIgDgHIgDgHIgEgIIgDgHIgDgIIgCgIIgCgHIgDgHIgDgIIgCgHIgDgIIAAgIIAAgHIgCgHIAAgIIAAgGIAAgIIAAgIIAAgHIAAgHIAAgIIAAgHIAAgIIAAgIIAAgHIAAgHIAAgIIAAgHIAAgIIAAgIIACgHIAAgHIAAgIIAAgHIADgIIAAgIIAAgHIACgHIAAgIIADgHIAAgIIADgIIAAgHIACgHIACgIIADgHIAFgIIACgIIAGgHIACgHIAFgIIADgHIAEgIIADgIIAFgHIAFgHIAFgIIAFgHIAIgIIAKgIIAMgHIANgHIAHgIIAPgHIAKgGIAHgCIAKgCIAXgDIBTgFIAMgIIAKgHIAPgIIARgHIAXgHIARgGIAXAAIAAgCIBFAAIAWACIAQAGIARAHIAPAHIAPAIIANAHIAMAIIAIAIIAHAHIAHAHIAGAIIAFAHIAHAIIAFAIIAFAHIAFAHIAFAFIAAADIANADIAPAEIARAIIAPAIIAPAHIAPAHIAPAIIAPAHIAMAIIANAIIAKAHIAKAHIAKAIIAKAHIAIAIIAHAIIAIAHIAEAHIAIAIIAFAHIAFAIIACAIIAGAHIACAHIADAIIAEAHIADAIIADAIIAEAHIAGAHIACAIIAFAHIADAIIAEAIIADAHIAAAHIADAIIAAAHIAAAIIACAIIAAAHIAAAHIAAAHIAAAHIAAAIIAAAIIAAAHIAAAHIAAAIIAAAHIAAAIIAAAIIAAAHIAAAHIAAAIIAAAHIAAAIIAAAIIAAAHIAAAHIAAAIIAAAHIAAAIIgCAIIAAAHIAAAHIgDAIIgDAHIgCAIIgCAIIgDAHIgDAHIgEAIIgDAHIgFAIIgFAIIgFAHIgFAHIgIAIIgHAHIgHAIIgIAIIgFAHIgFAHIgFAIIgIAHIgHAIIgHAIIgKAHIgNAHIgPAIIgPAHIgKAIIgKAIIgKAHIgNAHIgMAIIgUAHIgPAGIgIACIgJACIgXADIi9AAg
Thanks a lot, I looked at 10 forums for an answer to the question and nobody knew. Respect !
As a point of interest, I didn't know either! But I'm very good with Google, and knew enough to know what to look for.
I want to ask you something, when I write text there he pundit on different shape, how can I put it to be just a shape
Type some text into a textfield, then select the textfield and do Break Apart twice. That will convert the text into shape data. When you publish that the Javascript should give you the decodePath text for all of the letters in one chunk.
