Targeting Select All menu language independent
Mar 13, 2017 Mar 13, 2017
I have a script that adds a menu under the Select All menu.
But I can not target the menu language independent.
I tried "Select_All", "SelectAll' and even "Select All" but it does not work in other languages.
I'm using a Dutch install. When I insert 'Clear' it does add under 'Wissen' in the Dutch version (Wissen=Clear)
Now I'm using this:
var fileMenu = app.menus.item("$ID/Main").submenus.item("$ID/&Edit");
var refItem = fileMenu.menuItems.item("Alles selecteren");
Alles Selecteren is the Dutch entry for Select All, but I want to make this work in any language.
Does anyone know what to target as $ID here?
Scripting
728
Community Expert , Mar 13, 2017 Mar 13, 2017
Hi Frans,
Use: $ID/Select &All
Why?
var title = app.menus.item("$ID/Main").
submenus.item("$ID/&Edit").
menuItems.item("Alles selecteren").
title;
app.findKeyStrings(title);
// $ID/Select &All
Best look after the title of a menu item for feeding a special method that comes with app.
The name could be not reliable enough.
Uwe
Hi Frans,
Why?
title;
// $ID/Select &All
Uwe
Thanks Uwe!
The 'why': I reused part od a script I know works (it set a var as menu title used later).
I am no scriptet, just making little steps here 😉
Hi Frans,
you are welcome.
As you know I am working with the German version of InDesign.
My customers could work in virtually all localized versions.
So I always try to find the string that works for all if I have to work with menu items and scripting.
app.findKeyStrings()
will produce the ones.
If there is one.
And sometimes it produces two or more strings.
Then you have to test all one after another to find the appropriate one.
In my German version of InDesign I could ask the menu its name or title.
var name =
menuItems.item("Alles auswählen").name;
var name =
menuItems.item("Alles auswählen").title;
Returned are
name : "Alles auswählen"
title : "Alles ausw&ählen"
If I run:
app.findKeyStrings("Alles auswählen");
nothing will returned.
Wheras if I run:
app.findKeyStrings("Alles ausw&ählen");
$ID/Select &All will returned.
Uwe
Thanks Uwe!
I'm still finding my way in Javascript...
Mar 14, 2017 Mar 14, 2017
Uwe, I I may bother you one more time:
Adding a script to a menu works when using the local language:
var fileMenu = app.menus.item("$ID/Main").submenus.item("$ID/&Object").submenus.item("$ID/InteractiveContextMenu");
var refItem = fileMenu.menuItems.item("Tabvolgorde instellen...");
It does NOT work when using the independent menu-item:
var refItem = fileMenu.menuItems.item("$ID/SetTabOrder");
I'm out of my comfort zone here... 😉
I got the menuID by number for SetTabOrder, which should be 83469. Can not make that work either... 😞
Got it!
This worked:
var refItem = fileMenu.menuItems.itemByID(83469);
Hi Frans,
glad you found your way around.
BTW: The locale independent name of that menuItem is:
$ID/$$$/Menu/SetTabOrder
Uwe
Yes, still one thing that I can not get to work, and that is targeting Show/Hide Hidden Characters, That should be
fileMenu.menuItems.itemByID(119553);
But that keeps coming back as error.
A well, another night with little sleep I guess  😉
Hi Frans,
to make a menu item work, you have to check if it is perhaps grayed out under special circumstances.
Or if ir exists at all. In the moment you are asking.
For example: The functionlity behind "Set Tab Order…" is not available, if there is no or only one form field item positioned on the active page. It is grayed out.
For a menuItem you could look into the values of some important properties:
isValid
enabled
checked
isValid is the most important one.
If isValid is true, the menuItem exists in the moment you are calling isValid.
enabled means it is ready to use.
Not grayed out. See above where I did my little example.
checked could be true, false or not appropriate.
Some of the menuItems are simply not checkable.
And some change their names if you invoke their associated menu action:
"Show/Hide Hidden Characters" is one of them.
So it could be, that "Show Hidden Characters" is enabled and isValid.
Or "Hide Hidden Characters" is enabled and isValid. Both cannot be isValid at the same time.
And both states of that menuItem can never be "checked".
It can only change its name every time you invoke it.
The two strings are:
$ID/Hide Hidden Characters
$ID/Show Hidden Characters
Uwe
Strange enough that is NOT the case. It works fine in the Dutch version nl_NL, wether it is Show or Hidden, it attaches itself after the menu. Just like the ShowOverrides script did.
However, it results in an error in the en_US language (or other)...
AH!
Geez... must be tired:
I used: $ID&Text
Should be: $ID&Type
Then fileMenu.menuItems.itemByID(119553);  works!
Hi Frans,
after re-reading your posts before I now saw it as well.
The submenu you want to address is submenus.item("$ID/&Type").
Now you get the menu item by its ID number.
Very practically because this item has two different names and only one distinct ID number.
Usually I would hesitate to rely on a specific ID numbr of a menu item.
It remains to be seen if this ID number is always the same with different InDesign versions.
In the meanwhile I tested a bit by addressing the menu item. Whether it's in the one or in the other state. By ID or by name.
To my surprise I had a bit trouble to get the right state—"Hide Hidden Characters" vs. "Show Hidden Characters".
Sometimes it seems that InDesign returned the opposite what I was seeing in the UI.
I ran the following snippet a couple of times with inconsistent results. Inconsistent results occured if I changed the menu from one state to the other in the UI using my trackpad. But I could provoke the problem not very often.
Here the code:
var result = ["BEFORE/AFTER should be different:"];
var showHideHiddenChars =
result[result.length++] = "BEFORE"+": "+showHideHiddenChars.name;
result[result.length++] = "showHideHiddenChars.associatedMenuAction.invoke();";
result[result.length++] = "AFTER"+": "+showHideHiddenChars.name;
alert(result.join("\r"));
$.writeln(result.join("\r")+"\r"+"*****");
By invoking the menu item, its name should change.
From e.g. "Show Hidden Characters" (German: "Verborgene Zeichen einblenden") to "Hide Hidden Characters" (German: "Verborgene Zeichen ausblenden") and reverse. Usually it did. Here a good result:
But it also happened, that invoking the menu returned not a changed name.
Even so that a different name was visible with the UI and the function worked as expected.
Sometimes after I changed the menu item in the UI with the trackpad of my MacBook Pro.
But not always.
Tested with InDesign CS6 8.1.0 on Mac OSX 10.6.8.
Uwe
Thanks Uwe.
Yes, Text/Type... it was staring my right in the face but I missed it 😞
All is working now for me.
Mar 19, 2017 Mar 19, 2017
One more, that I can not solve:
I have the first basic PD script from Keith Gilbert, but that saves the files and folders in the same dir as the source document.
I would OR like to select the folder they files get saved in OR to create a parent folder.
I tried "new Folder (myDocBaseName + "HTML5 Export")" somewhere in the script to create a new parent folder in the same dir but that failed.
Any help is very, very welcome.
This is the source from Keith:
// Check to see whether any InDesign documents are open.
  // If no documents are open, display an error message.
  if (app.documents.length > 0) {
  var myDoc = app.activeDocument;
  // Build the filename
  var myDocName = decodeURI(myDoc.fullName);
  var myDocBaseName = myDocName.substring(0, myDocName.lastIndexOf("."));
  // Export the page to FXL HTML
  with (myDoc.htmlFXLExportPreferences) {
  epubPageRangeFormat = PageRangeFormat.EXPORT_ALL_PAGES
// epubPageRangeFormat = PageRangeFormat.EXPORT_PAGE_RANGE
// epubPageRange = "1-2";
  myDoc.exportFile(ExportFormat.HTMLFXL, new File(myDocBaseName + ".html"), true);
alert("De HTML5-export is klaar!");
  else {
  // No documents are open, so display an error message.
  alert("Er zijn geen documenten geopend!")
