AE 2017 macbook pro 2015- 16G, 2.5Ghz i7- im having incomplete renders. not sure why. I tried sending to a different hard drive (900Gb avail) and a few other things, but the render quits after the first second. it is 4K, so i created a new comp at 1920x1080 and dropped the main comp into that and dropped the size 50%. seemed to want to work, then quit rendering again. I tried setting my media cach and database to another hd with 100gb avail, tight, but nope. I dont mind putting it out at 2K. do i need to set up a new doc at 2K? also, its mostly vecotr .ai files with layers brought into ae. thanks!!
[Moved from non-technical Lounge Forum to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
ok, i went through the layers and the culprit was an animated .ai layer that had a gaussian blur AND cc slant and camera lens blur on it. it was basically the shadow of the body, so i wanted it to match the movements and camera blur effect that was on the subject. i pushed ae/mac too much with all that. now it seems obvious. i deleted it and it worked. thank you for the help!
What are your render setting?
What effects and plugins are you using?
How is the hard drive formatted?
When the render quits what sort of message are you seeing?
thank you for responding. Im trying different settings. .mov's- prores, h264, lossless. see attachments for render settings and hard drive info. using: camera lens blur a couple times. the piece is 7 seconds long. render quits right at the beginning after a few seconds with the "Baaah!" but no message. I just tried turning off frame blending and that didnt work.
Do you have any footage in your comp? If so, what format and codec is it?
What error messages are showing in the render queue and/or log?
no footage except 4K size .ai's.
would it matter if i shrunk the .ai's say 50% in illustrator and then doubled them in ae?
where is the render log? see attachments for render queue and ae clipboard error (which ive tried to solve by copying blank text, purged "all memory and cache" etc). the clipboard error seems to be two of them, i have to click on the same dialogue after the first goes away.
Can I see a screenshot of your AI save dialog for one of those files?
.ai file:
Also, you have tried copying something else, right? Like type out some text in a web browser and copying it?
Next suggestion would be to go into Illustrator's preferences to the File Handling and Clipboard section (towards the bottom of the options) and uncheck the PDF option for On Quit. And then copy...something in Illustrator.
It's pretty easy to create complex vector paths in AI that give AE problems. You should study up on creating Illustrator artwork for video. The basic rules are:
Until you have an experts understanding of video standards, frame rates and compression make sure that you use the presets for your comp size and your rendering settings. They will keep you out of trouble.
the only problem is i have the body parts separated in the .ai file and all the animation is already done in ae. i reshaped the .ai artboard to the same size, but it cut off the artwork in places. i then locked the size and raised the numbers to fit the artwork and made sure they both landed on even whole numbers. prob not correct, but if i shrink the artwork, it will all go screwy in ae, or maybe not. gonna try a test on that now...
oh, and yes i tried copying text.
No problem!
