Hello,
Since V0.6.16 of ED, the UNDO-Function doesn’t work anymore. Is it a Bug or do i something wrong? 😉
Klaus
Elaine will realize what the bug is then. It seems the first undo is assuming a US keyboard, but after that it behaves correctly.
Hi, Klaus-
This should definitely work - are you on Mac or Windows?
-Elaine
i am on Windows right now. i was testing the UNDO again.
- First I opened an old File,
- created some new Object and UNDO. Nothing happened.
- Next, I created a new File, placed some Rectangles… UNDO… No Undo.
- Closed the PRG, did the same thing again but changed the color of a Rectangle… UNDO… now, UNDO works.
- Since now, UNDO works from start too. Very strange, but maybe a Problem with old Preferences.
Unfortunately, we were unable to reproduce this on our side. Is there anything else you can tell us about your system? Are you using a QWERTZ keyboard?
-Elaine
Yes, i'm using a QWERTZ keyboard.
Sorry, don't have more Information for you.
Greetings
Klaus
If you do Strg-Y does it undo?
This is an issue coming from Windows. When the keyboard layout is changed (e.g. from ENG to DEU) the keys are not updated immediately for UWP applications. A workaround for this is to open a Win32 application like Notepad or the browser and type something into it. Or open the on screen keyboard. Afterwards the keyboard layout will be updated everywhere.
