I need to overlay two .tif files on top of each other... with both showing. I tried layers, but couldn't figure out how to have both visible.
If you have the option to send this file back to the illustrator, I'd go ahead and do that and just tell them what you need. That would be the easiest approach, and does not require you learning an additional program.
How do you expect to see them both if one is on top of the other? Do you want to see through one?
A screenshot or two would help...maybe.
I was sent a title page graphic and a title. Both are the same size, so I need to put both together so both show-- the cover page graphic in the lower right and the title across the top. So, I guess, yes, I want to see through one to the other-- which means one must be transparent to the other? Except I can't seem to get the correct combination, or select which graphic is up front and which is to the rear (I select, but see no changes). Now I've lost the text box on the title page graphic (way to the bottom of the page out of the way of the title graphic).
No screenshot, but picture a graphic taking the bottom 2/3 of a page and the title taking the top 1/3...
Do these files have transparent backgrounds?
The backgrounds are white behind text and white around the graphic.
When I make the text graphic fully transparent, the text disappears.
You need to remove the backgrounds in Photoshop. You could try the find edges feature in InDesign to remove it but that’s more of a down and dirty method.
I was very clumsily and slowly coming to that conclusion.
O goody! Something more to learn!
I'm watching blizzard conditions outside my window... and I have plenty to time on my hands. No way am I snow blowing this!!
Thank you!
A dud of a storm in South Jersey.
Not so much here in NY's Capitol Region! Strong winds, much snow = real blizzard conditions.
Thanks again!
Not sure if I'm missing something here, but can't you just crop each of the two graphics in their frames to hide the white background. It sounds like there is just a lot of opaque white surrounding each graphic.
Are you using Photoshop? I haven't see your title, so here are general steps:
This is good. However, my illustrator sent the file in such a was as to make that impossible. The error message tells me the text must be rasterized and it won't let me touch the background.
I either take Simon's solution (above) or send it all back to my illustrator to fix the problem at her end.
