I have recently tried up upload an InDesign document to Publish Online and am receiving an error that users will not be able to download the PDF. (Screenshot attached).
This was a slightly modified version of a document that I had no problems in the past uploaded to Publish Online. They were small editorial changes, so I do not know what is causing this error. The message gives no indication of the nature of the error. I can export it to an Interactive PDF from InDesign without difficulty.
As I would like users to be able to download a PDF copy, I would be interested to fix this issue.
Thanks in advance for any help.
--Bob
Did you try again?
Did you try again?
OK BobLevine, did you work some kind of magic?
Initially, I tried at least 4 different times, receiving the same error each time. I tried one more time after seeing your post and no error. Go figure. Thanks for the reply.
B.
You know that old saying that insanity is doing the same thing over and over again expecting a different result? Doesn't apply to InDesign.
