PS 2017 has become unusable
Mar 12, 2017 Mar 12, 2017
Windows 10
Geforce 1070, latest drivers
PS 2017.0.1
I keep getting the error pop-up doing just about anything in PS that there is a program error. Looking in the PSErrorLog.text file I see:
2017:03:13 02:17:31 : ..\..\framework\sources\ProxyProvider.cpp : 941 : REQUIRE failed
WHAT IS THIS???? PS has basically become useless! HELP!
I have no extensions except the default ones Adobe Color Themes and Default files.
No plugins installed.
I tried uninstalling and reinstalling.
I start with Alt Shift Ctrl to reset prefs. It works for a while then the program error pop-up fun begins again.
I also see this in my error logs:
2017:03:10 03:10:49 : 0000000000004090 of type struct _ARef * __ptr64 not found : 1 : REQUIRE failed
2017:03:10 03:10:49 : e:\ps17\ps_18_win_x64_daily_retail\20161130.r.29\photoshop\main\photoshop\interfaces\UTrackResourceImp.h : 137 : REQUIRE failed
Yet another error message is:
2017:03:09 16:42:37 : ..\..\sources\OwlPsEventController.cpp : 178 : REQUIRE failed
1.6K
Adobe Employee , Mar 13, 2017 Mar 13, 2017
In that case please go to Control Panel, and repair Microsoft Visual C++ 2012, 2013, 2015
Restart the computer and then try to open Photoshop and please let me know if it works.
Note: Do not forget to rename PlugPlugOwl.dll to its original name before launching Photoshop.
C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Adobe
Adobe Employee ,
Hi MI Photo,
Could you please check the event viewer when Ps crashes and post a screen shot of the crash log here?
Sahil
Where exactly do I look in the event viewer?
Adobe Employee ,
Please follow the steps mentioned below: -
  1. Click the Start button (Windows Logo).
  2. Click Control Panel.
  3. Click System and Maintenance.
  4. Click Administrative Tools.
  5. Double-click Event Viewer.
Once you have the event viewer opened click on the arrow near Windows Logs on the left to expand it.
Then click on Application.
Then you'll see the crash report in the middle window with a red symbol. If you double click on it, it will show the details of the crash in a separate window.
You can copy those details and paste them here.
Thanks for your assistance.
I've found two types of error logs that keep appearing, one for Photoshop.exe and another for Adobe Spaces Helper.exe. Copy pasting both in case it helps:
Faulting application name: Photoshop.exe, version: 18.0.1.29, time stamp: 0x583e911d
Faulting module name: PlugPlugOwl.dll, version: 7.0.0.67, time stamp: 0x57dcc2a8
Exception code: 0xc000041d
Fault offset: 0x000000000004c39e
Faulting process id: 0x78f0
Faulting application start time: 0x01d29b99b40e6072
Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Photoshop.exe
Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\PlugPlugOwl.dll
Report Id: ecffa231-8aba-4007-a040-b426c9af3a6f
Faulting package full name:
Faulting package-relative application ID:
Faulting application name: Adobe Spaces Helper.exe, version: 0.0.0.0, time stamp: 0x583e8a7d
Faulting module name: libcef.dll, version: 3.2526.1347.0, time stamp: 0x572d0cf0
Exception code: 0xc0000005
Fault offset: 0x0000000002656a12
Faulting process id: 0x98d8
Faulting application start time: 0x01d29b99b74da497
Faulting application path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\Adobe Spaces Helper.exe
Faulting module path: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\Spaces\libcef.dll
Report Id: 1d3cb763-6abe-4232-83a8-34a65ea02cec
Adobe Employee ,
Please refer to this article and try the solution mentioned and let us know if it helps Photoshop crashes with Lavasoft Chrome extension installed
I checked and I have nothing from Lavasoft installed in Chrome or otherwise.
Adobe Employee ,
Please go to the location mentioned below and look for PlugPlugOwl.dll and rename it.
Then launch Photoshop and let us know about the outcome.
Renamed it and when trying to launch PS it says it can't launch because it can't find PlugPlugOwl.dll
Adobe Employee ,
Please refer the article below to solve this issue Photoshop crashes with Lavasoft Chrome extension installed
You may also simply rename the file LavasoftTcpService64.dll to Old.LavasoftTcpService64.dll located:-C:\Windows\system32\LavasoftTcpService64.dll and that should fix the problem.
I don't have that dll in my system32 folder.
I mentioned in the previous message that I don't have anything from Lavasoft installed in Chrome or anywhere on my system.
Adobe Employee ,
Mar 15, 2017 Mar 15, 2017
Ok, I've done as you suggested to repair those, restarted and so far it seems things are back to normal, knock on wood. I hope it lasts.
Thank you for the assistance!
Adobe Employee ,
Mar 16, 2017 Mar 16, 2017
Glad, you got it working! Feel free to reach out to us for any future queries.
