Access to layers in onClick event handler
Mar 15, 2017 Mar 15, 2017
Hi. I'm trying to access all the layers in the current document when I click a button in a custom window that I am made. Here's my code so far:
var doc = app.activeDocument;
var palette = new Window("palette");
var button = palette.add("button", undefined, "Play");
palette.show();
button.onClick = function() {
    var numLayers = doc.layers.length;
    $.writeln(numLayers.toString());
The problem I am having is that the "layers" collection doesn't seem to exist in the active document when I try to access it in the onClick event. Perhaps there is something I don't understand about button event handlers?
Scripting
878
Adobe
Valorous Hero ,
This is because with palettes, this gets infinitely more complicated because you have to send the code as a string through the BridgeTalk object. See this thread for an explanation: Re: Calling functions from UI palette
Mar 16, 2017 Mar 16, 2017
Thanks Silly-V​. I was able to make illustrator send a message to itself. Here's the code if anyone else needs it:
#target illustrator
var loadCode = '$.writeln(app.activeDocument.layers.length);';
var animPalette = new Window("palette");
var button = animPalette.add("button", undefined, "Play");
animPalette.show();
// When button is clicked, create the BridgeTalk Object so we can send a message
// to an application (in this case its illustrator sending  a message to itself)
    var bt = new BridgeTalk;
    bt.target = "illustrator";
    bt.body = loadCode;
    bt.send();
// Callback for when illustrator recieves the message
// We use eval to read the message string and evaluate it as JS code
BridgeTalk.onRecieve = function( message )
    eval(message.body);
I'm curious though, is there a way to extract the script you want to run, into its own file as opposed to sending it as a string?
Valorous Hero ,
Hmm, I think using a palette, you have to send anything in a string regardless - but there may be more easier ways to do this.
You could, for example, try to send a simple message that points to a .jsx file and use the file.execute() on it.
In my case, I typically read in external .jsx files as text and send them through BT. There's a BridgeTalkEncode function floating around here, which is essential to ensure your script string stays intact and no comments or gotchas cause syntax errors.
Here's something I just threw together. This way of doing things allows you to encapsulate your logic in a method instead of writing it as a string. It still gets turned into a string when you send it to BridgeTalk but at least this way you don't have to write code in a nasty nasty string
// This method takes in a function
// and returns that function as a string + the function name and parenthesis
// so in the end it spits out a function declaration and invokation: "myMethod() {} myMethod()"
function strMethod(fn)
    return fn.toString() + fn.name + "()";
// The method we want to "stringify"
function addLayer()
    app.activeDocument.layers.add();
var message = strMethod(addLayer);
animPalette.show();
    bt.body = message;
    bt.send();
