Hello,
I'm importing an MP4 video into my Premier Pro/After Effects timeline and cannot get any audio track out of it.
Information:
The mp4 video does play audio playback on video-viewing programs (VLC WMP)
The video is from someone who edited the clip, I need to re-edit it.
What I've tried:
Clearing Cache. (100% cleared along with new destination for memory cache)
Exporting Audio only (mp3) from the file via Encoder CC. (Just produces a long silent audio file)
Exporting Mp4 into H264 via Encoder CC: It produced no sound.
PC Specs:
i7700k @ 4.2GHZ
16 GB Ram DDR4
GPU: NVidia GTX 970
Media Info:
General
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp41/mp42/isom)
File size : 1.08 GiB
Duration : 56 min 57 s
Overall bit rate mode : Variable
Overall bit rate : 2 727 kb/s
Encoded date : UTC 2017-03-03 00:19:17
Tagged date : UTC 2017-03-03 00:29:09
IsTruncated : Yes
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 4 997 kb/s
Maximum bit rate : 768 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Original frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.181
Stream size : 1.99 GiB
Title : Core Media Video
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Source duration : 56 min 57 s
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Thank you!
Hi brianf40169855,
Are you able to import audio in Premiere Pro?
Please attach a screenshot of Premiere Pro (after importing that clip)?
Is this issue happening with all of your clips or is it specific to one?
Kulpreet Singh
Yes I am able to import audio into Premiere Pro.
No, this is a clip specific problem.
Hi brianf40169855,
Please check this link: FAQ: MP4, MOV, AVCHD files import without audio in Premiere Pro CC (2015.3) and CC 2017
Kulpreet Singh
Hi brianf,
Have you tried the recommended steps, Please let us know the status.
Vidya
Its all in the source patching:
Have the "someone" who originally produced the clip export a .wav file of the timeline and use that for your reedit.
