Hello guys! I have a little struggle with lightroom, i am begginer and when i import a photo, it imports with a filter (kind of sepia filter). If you can help me, it'll be awesome. Thank you
You have a defective monitor profile.
I see you're on Windows 10, which is known to install low quality monitor profiles when doing updates.
The ideal solution is to calibrate the monitor with a hardware calibrator.
As a (temporary) fix, set the monitor profile to sRGB (or Adobe RGB if you have a wide gamut monitor).
Depending on how close your monitor's gamut is to sRGB/Adobe RGB, and your requirements, this may be good enough.
Press the Windows key+R, type colorcpl in the box, and hit Enter.
Add the
...Copy link to clipboard
Show us a screen capture of what you see.
^ How it looks when is imported, \/: how it looks when is in develop, and that s annoying because i can not compare original one with edited one
When develop colors don't match the library colors, that's almost always because you need to calibrate your monitor.
Add the sRGB profile, then set it as Default profile. See screenshot (from Windows 7) below.
Incredibly helpful! Thanks a lot guys!
