InDesign CC 2017 (up-to-date), Windows 7 64-bit Pro
We have master pages created with "linked text" (using Place and Link). When I "move" the master pages to a different document, the text moves fine, but the links between master page texts are removed. I thought links were supposed to remain when moving pages and master pages?
This should work as far as I'm aware - what workflow are you using?
Here's the workflow I tested that worked and retained the links OK.
Three documents
Steps used to test:
In my tests with InDesign CC (2017) this worked beautifully.
I am not using a source-text file at all. Master Page -1 has "page tabs" on it, and Master Page 2-6 have similar tabs with the exact same text. So on Master Page -1 I copied that text and did "paste and link" onto the other master pages. That way, I can update the text on Master Page -1 and "update" to the other tabs.
So the links would remain when I move the master pages to a new document as long as the text is in an external file instead, but only in that case? Thank you for the clarification!
My team ultimately decided to just do "find and replace all" in the end.
