Good morning,
I am working on a draft to make an interactive map with pop up MSOs.
I went through Bob Levine's masterful Lynda video prior to this topic. It is not that complicated from what I learned.
Unfortunately, I have not been able, with my files to replicate, either the nested MSO or the pop-up example using an MSO instead of a video.
Maybe someone can point out my mistakes.
Hopefully, my descriptions are not too complicated.
I have a start page with pin symbols on a map.
Afterwards, several individual pages will be inserted with individual MSO (5 or more states).
For the purpose of this demo, just one active pin, so just two pages (start and target).
Briefly, here what I tried.
I created a MSO from both pages (start and target).
I produced another MSO to nest within the pin target content.
I succeeded to nest the latter, but only the first state shows up.
I am probably not using the right sequence to achieve that.
After several tries, I thought it would be more productive to ask the Adobe Community.
I tried something else but not elegantly as the MSO process.
I kept both pages outside a MSO.
I used a pin button to get to the appropriated page.
I pasted a MSO to the pin target page.
It doesn't look that bad, even if the first two states are not properly rendered.
You can have a look by clicking the following link.
https://indd.adobe.com/view/455abb2d-a47f-4a63-92bf-28f0098c5cc5
Any advices to find a more elegant solution would be appreciated.
Thanking everyone in advance.
Pierre-Y. Plourde
You can't nest them across pages so you can forget about that.
As for the rest, without studying the files, it's almost impossible for me to tell what's going on.
Someone mention my name?
The map in the background should remain static, not part of the MSO. The first state can be the pins along with buttons to the other states.
Each additional state would be the info for the geographic area you want to highlight along with a “close” button that would take you back to the first state.
I’m not sure what you’re after as far as the rest of the project.
Indeed Bob!
I will take a look and try to make it work.
This is just a small prototype to explore the MSO options.
Much more easy though with your exercices files.
Many thanks.
Almost sure to post again to get some additional clues.
Le 16 mars 2017 à 15:30, BobLevine <forums_noreply@adobe.com> a écrit :
Advices needed with regard to nested MSO
created by BobLevine <https://forums.adobe.com/people/BobLevine> in InDesign EPUB - View the full discussion <https://forums.adobe.com/message/9396533#9396533>
If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/9396533#9396533 and clicking ‘Correct’ below the answer
Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/9396533#9396533
To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"
Start a new discussion in InDesign EPUB by email <mailto:discussions-community-indesign-indesign_epub@adobe-v8.hosted.jivesoftware.com> or at Adobe Community <https://forums.adobe.com/choose-container.jspa?contentType=1&containerType=14&container=5001>
For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624 <https://forums.adobe.com/thread/1516624>.
This email was sent by Adobe Community because you are a registered user.
You may unsubscribe <https://forums.adobe.com/unsubscribe.jspa?email=pwhyp5%40gmail.com&token=a438f6d62c325f9ea785c20f4a5688b059157b30cc9b681d8a3d77211f5c9978> instantly from Adobe Community, or adjust email frequency in your email preferences <https://forums.adobe.com/user-preferences!input.jspa>
Good afternoon again,
I still have two concerns with my project.
First
I am trying to nest the MSO (Cascades) from page 2 into the MSO (Circuit) state Terrasse (page 1).
This is maybe quite simply impossible to do. I tried with the textbox trick to no avail (How to add an MSO to a state...).
Indesign file is attached if someone is interested to take a look.
Second
This one is puzzling. When I use the ePub Interactivity Viewer Tool, the MSO (Cascades) from page 2 looks fine.
However, after Publishing the document Online or Exporting in ePub, the first two states are not properly displayed.
The ePub file attached comes from a prior attempt.
Thanking you a lot for your patience.
PYPlourde
https://www.dropbox.com/s/mdlrk945or5hr4t/PYPlourde.zip?dl=0
Thanks a lot for your answer.
Have a good day.
PYPlourde
pierre-y.p42664585 wrote
… However, after Publishing the document Online or Exporting in ePub, the first two states are not properly displayed. …
Hi PYPlourde,
what exactly is "not properly displayed"?
In that attempt I can see that the image is not changing when going from state 1 to 2 to 3.
But since your provided InDesign document does not reflect what you were doing in the moment you exported that fixed layout EPUB I cannot tell what's wrong.
I published online your InDesign test document and see no principal problem with the MSO on page 2.
Since you did not provide the images the preview of two images is missing in state 1 and 3.
Can you provide a screenshot where you mark what's going wrong?
To make the sceenshot visible use the forum's "Insert Image" control at the top bar of your reply editor:
Uwe
Good morning Uwe,
I published online the last version.
https://indd.adobe.com/view/82b5ba87-cb45-43ed-a4f5-2bf64791fab6
I attached my InDesign file.
My problem is exactly that, like you said, the image is not changing when going from state 1 to 2 to 3, as shown by the screen captures attached taken from the link provided after publishing the document online. Everything works fine from ePub Viewer Tool.
Here five screen captures.
From epubViewer tool (2) and after published online (3).
Dropbox - screenCapturesPlourde.zip
For your information, I would like to add that two of the five elements, within the MSO (#1 and #3), are OAM.files imported in InDesign.
Hope this help. If you need the original files to get a thorough look, just ask.
Many thanks.
PYPlourde
Hello again,
After different tries, I probably found the culprit. Apple Safari.
Sorry, I should have tested that prior to my request.
When I used the link provided by Publish Online, there is no problem with Google Chrome.
PYPlourde
Hi PYPlourde,
ah. Thank you for this.
Initally I tested with Firefox on Mac OSX.
Now did a test with Safari 10.0 on OSX 10.10.5 and can confirm the problem with the MSO.
The wrong preview image is showing in state 1 and the wipe effect does not work. Also wrong image in state 2. Supposed wipe is not working. Wipe is only working with state 3.
Hm. The wipe effect comes with the used oam files.
Maybe that's why Safari cannot cope with it?
With Firefox no problems:
1. Click the button on page 1 on the map and I will go to page 2 showing the MSO.
3. Clicking through the different states of the MSO works as expected. Could use the wipe effect in state 1 and state 3.
4. Using the close button in the right top corner of every state brings me back to page 1.
Uwe
Hello Uwe,
It was three months ago…
I recently needed to take a deeper look into the actual topics.
I found interesting things I would like to share.
All files used in this demo are provided with the Dropbox link attached.
(https://www.dropbox.com/s/gwu2pjyg8wq5gtg/AdobeMSO.zip?dl=0)
This a simple 4 page Indesign (CC 2017 prior to the last iteration) document (testPYP.indd).
Page1. Wipe effect imported from OAM file
Page2. Picture1
Page3. Picture2
Page4. MSO with three states (picture1, picture2, OAM file (wipe effect) from page1)
I used this file to check the proper rendering from a desktop computer (iMac – Mac OS X 10.11.6) and a portable device (iPad Pro 9.7 with the latest version of iOS).
Here my findings.
A-From within InDesign EPUB Previewer, everything is fine and runs smoothly.
B-Things are not so optimal after the Publish Online process.
Here is the link (https://indd.adobe.com/view/4d664d39-0fa9-4ae9-9a5d-3661628590ba).
Desktop
All four pages run perfectly with Google Chrome.
The wipe effect in the MSO (page #4) is not recognized by Safari.
Mobile device
In both, Chrome and Safari mobile, the wipe effect in the MSO (page#4) is not working properly.
C-ePub export not right either
Desktop
In Adobe Digital Editions, both pages (#1 and #4 (MSO State 3)) with the imported OAM file, are not working properly. Just lines of code are showing up (Screen capture attached).
In iBooks, the MSO (page#4) is not working.
Mobile device
In iBooks, the animation in page#1 (OAM file) and (page#4 (MSO State 3) are not working.
I would greatly appreciate your help to make the whole thing work, if possible.
Many thanks in advance.
PYPlourde
