Hi there,
My scripted Illustrator workflow involves working with a lot of files with legacy text. The script I use to open these files creates an OpenOptions() object, to which updateLegacyText is set to true.
var fileRef = File("c:\script_path\myfile.ai")
var optRef = new OpenOptions();
optRef.updateLegacyText = true
var docRef = open(fileRef, "null", optRef);
When I run this script using ExtendScript Toolkit, no problem -- the file opens and all the legacy text is updated.
However, when I run the script from the command prompt...
illustrator.exe -run c:\script_path\my_script.jsx
Everything works EXCEPT I still get a pop-up asking whether or not I want to open legacy text.
This may seem like a small inconvenience, but it means that this process cannot be fully automated. If I need to process dozens of files, I would need to be present to click "Okay" at each pop-up.
I find this behaviour odd, since it works fine when run from the ExtendScript Toolkit. Is anyone aware of this problem? I am using the latest version of Adobe CC 2017.
Thank you very much for any help you can provide
Try including:
app.userInteractionLevel(UserInteractionLevel.DONOTDISPLAYALERTS);
Try including:
Yes! That worked. Although formatting is:
app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS
Thank you very much!
gah, you're right. the documentation doesn't have an example and it's been a long time since i used it so i took a shot in the dark..
Glad you were able to get it working. 😃
