When I run the msi from a command line (msiexec /i "install_flash_player_25_plugin.msi" /qn /norestart) Flash appears to install, and it's listed in Programs & Features, but, it doesn't actually install. This is the same method I have used to install Flash for a few years without issue.
I've replicated this issue on multiple Windows 10 Enterprise x64 boxes.
I tried the same at our end but could not reproduce the above mentioned behavior. Are you running the command prompt as administrator? If not please try the command again with cmd run as administrator.
In case you still see some issue please let us know.
Yes, it is being run from an admin command prompt.
Please run the MSI installer again and create a log file with the v+x options (verbose + additional debugging) enabled.
After installation completes upload the verbose MSI log file and the FlashInstall.log files from C:\Windows\System32\Macromed\Flash AND C:\Windows\SysWOW64\Macromed\Flash directories to cloud.acrobat.com/send using the instructions at How to share a document and post the link to the uploaded files in your reply.
Maria
Thank you for the log files. We'd like to get more information on your deployment process:
Thank you.
Maria
1. No, I was not using a deployment tool. I was testing prior to deploying though SCCM.
2. The installer is being run through an admin command prompt.
3. If I run the MSI directly, the installation succeeds.
According to the log files, the most recent installation attempt was successful. Is this when you installed in UI mode?
Please provide the MSI install log file with the v+x options enabled. If you need to run the installer again to generate the MSI log file, I need updated FlashInstall.log files that include the failed installation attempt.
Thank you.
If the MSI is run directly, the install is successful. Through command line, however, it fails.
I understand that. Please provide the MSI log file (with v+x options) for the failed command-line installation. And updated FlashInstall.log files that contain logging for the failed installation.
