When I open Organiser V15 it immediately flags up Eelements 15 Organiser has stopped working. Close program.
Photo Editor and Video Editor are working fine. Orgaiser fails even if I try to open it after Editor is open.
Where do I even start to locate the problem? I am at a loss how to find the problem.
Sorry for the inconvenience.
First of all, please try creating a new catalog and see if gets created.
To create a new catalog, perform following steps:
1. While launching Organizer, keep Shift key pressed
2. Catalog Manager dialog will pop up
3. Click on New to create a new catalog
If you are able to create a new catalog without Organizer crashing, -
4. Go to Edit > Preferences > Files
5. Uncheck the option to automatically generate thumbnails of video files.
6. Once done so, switch back to your older c
...Copy link to clipboard
Can no one help me on this? I don't even know where to start looking for the problem.
6. Once done so, switch back to your older catalog from File > Manage Catalogs
If issue still persists, I would request you to please share Event Viewer logs. Follow the steps mentioned in Photoshop Elements Editor Help | How to Find Crash Logs on Windows to get those logs
Anwesha
Thank you Anwesha. That worked perfectly and PSE is up and running again. There were several video icons which I have now deleted from the catalog.
Many thanks for your help.
I had the same problems. I reinstalled PSE 15 and the problem persisted. I include the event. Is this the same problem that sydhsydh had? Windows 10 Pro 64 bit, 16 GB ram.
Faulting application name: PhotoshopElementsOrganizer.exe, version: 15.0.0.0, time stamp: 0x57cd427e
Faulting module name: CompPkgSup.DLL, version: 10.0.14393.953, time stamp: 0x58ba5c12
Exception code: 0xc0000005
Fault offset: 0x000000000000349d
Faulting process id: 0x28e0
Faulting application start time: 0x01d2a819972786a9
Faulting application path: E:\Program Files (x86)\Elements 15 Organizer\PhotoshopElementsOrganizer.exe
Faulting module path: C:\Windows\System32\CompPkgSup.DLL
Report Id: 8f511193-18fb-4ed2-83b7-8c7410e4232d
Faulting package full name:
Faulting package-relative application ID:
DETAILS
15.0.0.0
57cd427e
CompPkgSup.DLL
10.0.14393.953
58ba5c12
c0000005
000000000000349d
28e0
01d2a819972786a9
It was certainly a DLL that flagged up in the events but not sure if it was the same as you have listed. My PSE crashed immediately after opening but it was long enough for me to see several videos had appeared in the catalog. I would suggest you perform the actions above by creating a new catalog just so you can uncheck the video option. If you have no videos in the catalog, then this is probably not your problem.
Thanks. I did have plenty of videos but things were either going too fast or nothing pointed to videos as being the problem before Organizer simply stopped working. So far this "fix" has stopped the freezing of PSE. Strange that the video thumbnails would cause the problem. Does Adobe know about this?
Followed instructions and it worked like a charm! Thank you.
