Hallo
Telkens als ik een foto wil opslaan met de maat 2160 x 1440 dan maakt Lightroom er 2160x1212 van.
Hoe kan ik dit oplossen?
Groet
Bart Ebisch
Use the crop tool (press R) and select 3x2 from the dropdown menu
You have to first crop the image to 3x2 aspect ratio (which is the equivalent aspect ratio to 2160x1440)
never had problems with it, until yesterday.
maybe I did change something I am not aware of.
I do I do crop to 3x2 aspect ratio?
Did found it. I will loose a lot of the photo's
Do you have any idea why 2160x1440 works with single photo's, but not when I stack 3 pictures and save them as hdr-pictures?
Explain in a lot more detail. Give examples. State the size of your photos in pixels and each and every step you are following.
I have to make real estate picturesm in 2160x1440 format.
What I do:
-Shoot 3 pictures for every locatie
-Make hdr of them with plugin Enfuse.
-Enfuse will make tiffs of the pictures.
-For fininishing touch I use Lightroom en save them as jpg, 2160x1440.
Did you crop the photos to 3x2 aspect ratio before export them from Lightroom?
No I did not.
Mysterious ways. Now everything works correct again.
In order to get a 3x2 aspect ratio export, you must crop to 3x2 aspect ratio (or ... the photos must be originally having that aspect ratio)
Normally NEF's are 6016x4016.
But in brackething mode they were 6016x3376.
No idea why.
I Ended brackething setup and started it again. Now I get the format I want.
