SEAMLESS OBLIQUE LINES FROM BRUSH
Participant ,
Mar 17, 2017 Mar 17, 2017
Hello to evretybody
Someone could help me to create a seamless
oblique lines pattern from a line drawn with a brush ?
It's possible to do it ?
793
Community Expert , Mar 19, 2017 Mar 19, 2017
To check and fix seams use the Offset Filter and touch them up before defining the new Pattern.
Adobe
Use the Offset Filter to get the »seams« to the center of the page’s height and width, then touch them up.
The resulting image should work as the basis of a Pattern (Edit > Define Pattern).
Participant ,
Sorry but i think i do not understand. This is what happen if i use the offset filter
Lines are not connected
Your original screenshot showed a vertical line …
Basically you can still
• start with a »vertical«, square Pattern
• create a Pattern Fill Layer that is at least twice the size of the Pattern tile
• convert it to a Smart Object
• rotate it 45˚
• select a square area of 141.4% the size of the original tile and define a new Pattern
Participant ,
Sorry man be patient but i wouldn't know how to how to create a square selection starting exactli from the ceneter and 141,4 % ?
You can store the Selection used to define the first Pattern as an alpha Channel, load that later on and use Select > Transform Selection to increase it to the intended percentage by entering the values in the Options Bar.
Participant ,
I don't know how to save a selection to the alpha channels
Hit the »Save selection as channel«-button in the Channels Panel.
Participant ,
it does not give me the option to define the selection as a pattern
Participant ,
could you create a clip of the procedure.i'm doing really hard to understand
How large Is the image in pixels?
Participant ,
7093px high – do you really need that big a Pattern?
I suspect you may be wasting your resources here.
The size is not the issue, though, I seem to have no problem defining a Pattern that big.
Participant ,
In fact the problem is not the size. I need to use that size cause is for fabric printing.
The real  problem is not even to create an obliqe line pattern.
The real problem is create a SEAMLESS pattern starting from a brush line.
is this possible?
I know that i'm not  too mutch skilled so please be patient
Participant ,
The problem is that inside the brush is an effect
