Hello
I build a menu for the alternative mobile site with the composition widget. It is a one page site with anchors. After clicking and jumping to the anchor the menu closes.
see the set up in the screen shot below. On my iPhone the menu works fine. On Android the menu does not close, what can i do.
Here the link: http://studionestor.de/test/
PS: I just saw it works on samsung but not Sony
thanks for helping
I have identified your issue and it is happening in the latest chrome update - 56.0.2924.87 only.
I have notified this to the engineering team and a bug will be logged very soon regarding this.
Stay tuned for further update.
Ankush
Hi querstion1,
Let me check with the team and get back to you on this one.
Preran
This looks like a device specific issue.
Please check if you noticing it in a particular browser or each browser of Sony phone.
If it is working on Chrome browser of Samsung so shall be fine with Sony as well.
Ankush
Hello Ankush,
I will check about the browser and get back to you asap. In the meantime I wrote down the version of Chrome and Android where the widget is working and where it is not working. Maybe this is helpful for your.
CY Max
Not working under Sony Xperia
Chrome 56.0.2924.87
Android 6.0.1;D5803 Build/23.5.A.0.575
Not working under ThL T5
(the phone is not available at the moment so I can only give you the browser version)
Chrome 56.0
Android ?
Working under ZTE Blade L3
Chrome 54.0.2840.85
Android 5.0.0;ZTE Blade L3 Build LRX21M
Hello Ankush
The widget works under the Firefox on Sony Xperia but the widget does not work on other Sony phones with Chrome 56.0.2924.87 (see below)
Can you give a solution, so the widget will work also under Chrome.
Regards Max
Working under Sony Xperia
Firefox 52.0.1
Chrome 56.0.2924.87
Android 5.1.1;C6603 Build/10.7.A.0.228
Create a new site with only one page and only the misbehaving elements (the composition), which demonstrate your issue. (This is helpful because it saves download and analyzing time).
Upload this .muse file(!) to Dropbox or a similar file sharing service and provide the download link here.
Then we can have a closer look.
Ankush
Hello Ankush
I created the new site with only one page and only the misbehaving element and uploaded it to the following url:
http://www.studionestor.de/misbehaving_element.zip
So you can have a close look and give me the solution for make the widget work on Chrome 56.0 aswell.
Appreciating your support, thanks
Max
Ankush
Hello Ankushr
can you give me news about the bug. It is about 10 days ago your last response and I really need a solution for this issue.
Thank you for a quick reply.
All the best Max
Hi Max,
The bug has been logged for this and you can expect a fix by our next release.
However, as of now we don't have any tentative release date.
Meanwhile you can activate the close button so that the menu can be closed manually as a workaround.
Hi Ankushr
Thank you for your answer. How long will it take for the engineering team to solve the bug. Because activating the close button is not working as a workaround for the menu.
Max
For your workaround:
Without seeing the .muse, it looks like, you have set this one to hide on rollout instead of hide on click (german sounds different, that´s why I put the screenshot).
Hello Fotoroeder
Thank you for your message. The workaround (changing from »hide on rollout« to »hide on click«) does not do what is needed: closing the menu and jump to the anchor, and it makes the menu not work anymore for all other platforms where it was working so far (iPhone safari, Android firefox)
I better wait for the engineering team to solve the bug.
How long will it take to solve the bug. Can you give a rough estimate.
Cheers Max
Sorry, yes you are right. I first only tried it on desktop, there I could´t even reach the menu because moving the pointer to the menu makes the menu disappear.
I also realized, that even in desktop version, the menu does`t close.
And – I was not able to pin your composition to the top left. So it would disappear after arriving the next anchor.
I could only solve it with a new file.
Uwe
Please see below thread and verify if your issue is fixed with latest build Muse 2017.0.3.20.
Adobe Muse CC 2017.0.3 is now live
I use Muse 2017.0.4.8 and the issue still exists.
