Smart object Antialiasing
Mar 16, 2017 Mar 16, 2017
I have a problem with Smart Object antialiasing after warp transformations.
Maybe someone know the solution for this problem because the effect I'm receiving is quite unacceptable. I'm attaching an example that will probable explay everything quite fast.
2.9K
Community Expert , Mar 17, 2017 Mar 17, 2017
Thanks.
My recommendation (edit: for a work-around, not a »solution« per se): Convert the Warped SO to an SO, open it, double its resolution (or increase it even more), save it.
With »123_01.psd« at least the result seems pretty OK to me.
Adobe
Hi tadeuszj,
Have you tried a different Image interpolation method (Like Bilinear) for Anti-aliasing? Take a look at the different interpolation methods in this link Photoshop image size and resolution
Let us know if that helps.
Akash
Yes Akash,
I tryed changing interpolation methods (in Preferences/General). Nothing helped.
Can you provide the file (containing just that one warped SO) for testing?
Soor. I'm attaching two examples.
WeTransfer
Thanks.
the "work-around" solving the issue a bit for me (I tripled the dpi number) - at least now it's more or less acceptable.
Thank you c.pfaffenbichler  for help and solution.
Adam
PS. no 123_01.psd wasn't even close to acceptable 😜
Mar 19, 2017 Mar 19, 2017
WIth Image Interpolation set to Bicubic Automatic I get the result on the right (when the newly created Smart Object is up-sampled to 144ppi), on the left is the original:
