Greetings! I previously wrote this script​ for incrementing file names in Photoshop quickly. It's sloppy code, but it works as expected.
Today I decided to clean the code up and move some lengthy code that gets used twice into a separate function. The new code is below.
The new JPEGSaveOptions(), new PNGSaveOptions(), new PhotoshopSaveOptions(), and new TiffSaveOptions() commands were moved from the main body of the code to the function saveFile at the bottom of the code. When Photoshop executes these lines (in red below) to instantiate new SaveOptions objects, it crashes without error message. There is no error noted in ExtendScript ToolKit, which continues running just fine.
Any ideas why this would happen? I'm guessing it's related to the scope of the document, but I'm not sure what the remedy would be aside from reverting back to the unabstracted code.
Thank you all for your time and help! :]
// Script by Vince Petaccio of PetRok Studios. | www.PetRokStudios.com
// Ensure a document is open
if ( documents.length > 0 )
// Change dialog settings
var originalDialogMode = app.displayDialogs;
app.displayDialogs = DialogModes.ERROR;
try
// Get the document
var docRef = activeDocument;
// Get the path for the document
var filePath = docRef.path + '/';
// Get the filename of the document
var fileNameNoExtension = docRef.name;
// Split the filename at the dots
fileNameNoExtension = fileNameNoExtension.split( "." );
// If there's a dot, remove everything after the last dot
if ( fileNameNoExtension.length > 1 ) {
// Get the file type
fileType = fileNameNoExtension[fileNameNoExtension.length-1];
// Decrement the filename object by removing the last element (the stuff after the last .)
fileNameNoExtension.length--;
// Reconnect everything BEFORE the first .
fileNameNoExtension = fileNameNoExtension.join(".");
// Get the last five characters of the filename
lastFive = fileNameNoExtension.slice(-5);
allButFive = fileNameNoExtension.slice(0,-6);
// Check whether the last five characters are digits
newDoc = isNaN(parseInt(lastFive))
// If this is a new document, then add _00000 to the file name
if (newDoc) {
// Make the new file name
newFileName = fileNameNoExtension + '_00000';
// Do the saving
saveFile(fileType.toLowerCase(), docRef, newFileName)
// Otherwise, find the lowest number of the file name that does not exist, starting at the index of the file name's digits
else {
// Create the needName switch
needName = 1
// Get the file number
fileNumber = Number(lastFive);
while (needName) {
// Increment the file number
fileNumber = fileNumber + 1;
// Make the file number 4 digits with zeros
switch ((fileNumber.toString()).length) {
case 1:
newFileName = allButFive + '_0000' + fileNumber.toString();
break;
case 2:
newFileName = allButFive + '_000' + fileNumber.toString();
break;
case 3:
newFileName = allButFive + '_00' + fileNumber.toString();
break;
case 4:
newFileName = allButFive + '_0' + fileNumber.toString();
break;
case 5:
newFileName = allButFive + "_" + fileNumber.toString();
break;
// Do the saving
needName = saveFile(fileType.toLowerCase(), docRef, newFileName)
catch(e)
// An error occured; restore dialog mode and display the error
app.displayDialogs = originalDialogMode;
throw e;
else
alert( "There's no file open! GET TO WORK!!!!");
// Function for saving the file
function saveFile(fileType, docRef, newFileName) {
needName = 1;
switch (fileType.toLowerCase()) {
case 'psd': // Photoshop file
thisSameFile = docRef.path + '/' + newFileName + '.psd';
saveFile = new File(thisSameFile);
if (saveFile.exists) {
break;
else {
saveOptions = new PhotoshopSaveOptions();
saveOpt.embedColorProfile = true;
saveOpt.layers = true;
app.activeDocument.saveAs(saveFile,saveOpt,true,Extension.LOWERCASE);
needName = 0;
app.activeDocument.close(saveOpt.DONOTSAVECHANGES);
open(saveFile);
break;
case 'jpg': // JPEG file
thisSameFile = docRef.path + '/' + newFileName + '.jpg';
break;
else {
saveOpt = new JPEGSaveOptions();
saveOpt.formatOptions = FormatOptions.STANDARDBASELINE;
saveOpt.matte = MatteType.NONE;
saveOpt.quality = 12;
needName = 0;
open(saveFile);
break;
case 'png': // PNG file
thisSameFile = docRef.path + '/' + newFileName + '.png';
break;
else {
saveOpt = new PNGSaveOptions();
saveOpt.compression = 0;
needName = 0;
open(saveFile);
break;
case 'tif': // TIFF file
thisSameFile = docRef.path + '/' + newFileName + '.tif';
break;
else {
saveOpt = new TiffSaveOptions();
saveOpt.layers = false;
saveOpt.transparency = true;
needName = 0;
open(saveFile);
break;
return needName;
The problem seems to be is that you seems to be using "saveFile" as both a Function Name and a Variable. I changed the function name to saveFileF
...// Script by Vince Petaccio of PetRok Studios. | www.PetRokStudios.com
try
// Get the document
What crashes? Photoshop? Have you tried running the script in Photoshop not using ExtendScript ToolKit run it from Photoshop menu File>Scripts>Script File. Was a crash report generated? Running your script that way on my system the Photoshop crash is in extendscript.dll.... Even when the save option code is commented out it crashes so it not the statement in red causing the crash...
try
// Get the document
if (newDoc) {
// Do the saving
else {
needName = 1
while (needName) {
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
// Do the saving
catch(e)
throw e;
else
needName = 1;
break;
else {
needName = 0;
open(saveFile);
break;
break;
else {
needName = 0;
open(saveFile);
break;
break;
else {
needName = 0;
open(saveFile);
break;
break;
else {
needName = 0;
open(saveFile);
break;
return needName;
Hi JJMack, thanks so much for taking the time to help me out!
The crash does indeed occur when I run the script this way, in both CC 2015 and in CC 2017.
The mode of failure is a "Photoshop has stopped working..." error, depicted below.
Curious that you've encountered the error with that line commented out- when I run the code in debug mode, it runs perfectly until it crashes as those lines. This is what lead me to the conclusion that the problem was related to them. Though I wouldn't expect the code to run with those lines commented out, since they define variables used later in the code.
try
// Get the document
if (newDoc) {
// Do the saving
saveFileF(fileType.toLowerCase(), docRef, newFileName)
else {
needName = 1
while (needName) {
case 1:
break;
case 2:
break;
case 3:
break;
case 4:
break;
case 5:
break;
// Do the saving
needName = saveFileF(fileType.toLowerCase(), docRef, newFileName)
catch(e)
throw e;
else
function saveFileF(fileType, docRef, newFileName) {
needName = 1;
break;
else {
needName = 0;
open(saveFile);
break;
break;
else {
needName = 0;
open(saveFile);
break;
break;
else {
needName = 0;
open(saveFile);
break;
break;
else {
needName = 0;
open(saveFile);
break;
return needName;
WOW do I feel silly. Amateur hour in here, eh?
Thanks so much for your help! Everything is working as expected now with that change.
