Hello
How can we add equal sign ( = ) at end of the first page of a continuous footnotes and at the beginning of the second page of continuous footnotes .
and how can we automate this .
Example :
Can you help me please .
Several questions come to mind:
Why do this? It is highly non-standard.
What version of InDesign are you using? What OS?
because of client
CS6
windows 10
On the one hand, it isn't done that way, but a paying client can be persuasive, I do realize!
Further, InDesign does not have a capacity for this.
It might be scriptable, but I rather doubt it. What the InDesign Scripting community comes up with often amazes me, tho.
Join the Rebellion! … If needed, light-saber hit again (layout changes)!
0127_TwoPagesFootnote_MichelAllio.jsx
Script written by Michel Allio [2017/03/18]
app.doScript("main()", ScriptLanguage.javascript, undefined, UndoModes.ENTIRE_SCRIPT, "2-Pages Footnote! …");
function main()
var myDoc = app.activeDocument;
myDoc.conditionalTextPreferences.showConditionIndicators = ConditionIndicatorMode.HIDE_INDICATORS;
// TO BE MODIFIED! --------------------------------------------------------------------------------------------------------------
var myFootnotePStyle = myDoc.paragraphStyles.item("Footnote"),
myTracking = -10, myHorizontalScale = 99;
// CREATED BY SCRIPT! -----------------------------------------------------------------------------------------------------------
if (!myDoc.conditions.item("2-pages_Footnote").isValid) myDoc.conditions.add ({name: "2-pages_Footnote", indicatorMethod: ConditionIndicatorMethod.USE_HIGHLIGHT, indicatorColor: [255,255,255]});
var myCondition = "2-pages_Footnote";
app.findGrepPreferences = app.changeGrepPreferences = null;
app.findGrepPreferences.appliedConditions = [myCondition];
myDoc.changeGrep();
app.findGrepPreferences.appliedParagraphStyle = myFootnotePStyle;
myFound = myDoc.findGrep();
var F = myFound.length;
for (var f = 0; f < F; f++) {
var myLines = myFound
.lines, L = myLines.length;
for (var l = 1; l < L; l++) {
var myLine = myLines
; if ( myLines[l-1].characters[-1].parentTextFrames[0].parentPage !== myLines
.characters[0].parentTextFrames[0].parentPage ) { var myLine0 = myLines[l-1],
myLine1 = myLines
; myLines[l-1].characters[-1].contents = "\u2002= =\u2002";
myLine0.tracking = myLine1.tracking = myTracking;
myLine0.horizontalScale = myLine1.horizontalScale = myHorizontalScale;
app.findGrepPreferences.findWhat = "~>= =~>";
app.changeGrepPreferences.appliedConditions = [myCondition];
myDoc.changeGrep();
Hi Obi-wan,
your script will not work as expected, if the two == are a substitute for a hyphen.
I already asked this here in the InDesign scripting forum:
Before running your script:
After running:
You see, that a character is missing.
That would also be the case after re-running the script on non-hyphenation situations after the text were edited so that the two = moved away.
I would do it with a different concept in mind:
Do not change the text of a footnote, instead add the two = with some extra text frames that cover a potential hyphen also using text wrap to give room to the new two characters.
Just to give you an idea without scripting anything:
Before:
After:
Changing the view:
Uwe
Uwe,
i don't really know if the op talk us about an hyphenation sustitute!
If the case, maybe a way would be to avoid hyphenation between the two parts of the footnote! 😉
In my script approach, I've forgotten to reset the tracking/horizontal scaling at the beginning of the script!
Maybe a better way to treat this point would be using the insertion of 2 non-joiners associated to 2 grep styles! 😉
On this point, I've a question for you: i've no problem to check a condition or a char style (to create them if they don't exist yet in the doc), but how could I check a nested grep style? Add one is easy but verify if it exist? Thanks!
https://forums.adobe.com/people/Obi-wan+Kenobi wrote
… On this point, I've a question for you: i've no problem to check a condition or a char style (to create them if they don't exist yet in the doc), but how could I check a nested grep style? Add one is easy but verify if it exist? Thanks!(^/)
That would be a perfect question for the InDesign Scripting forum 🙂
Uwe
Yeap! Going to post it! =D
Uwe,
I confirm about this point:
Uncheck the "Césure sur la colonne" radio button!
I think the op only wants to show to the reader a footnote jumps on 2 pages!
… I think the op only wants to show to the reader a footnote jumps on 2 pages!…
Then I'd perhaps do it at the end of a paragraph or a line where the text ends with a sentence.
If you think of a scripted solution, do not forget about a situation where a footnote jumps from one column to another one on the same page.
Uwe
… More and more complex!
Including a "page" check!
I adore you guys for the scripting magic, but I wish you wouldn't enable the OP to make something that looks like this!
