How to 'Paste Into' text into a Shape without loosing the words around the edge of the shape?
Mar 18, 2017 Mar 18, 2017
I am trying to copy some text into a shape (kind of like a clipping mask) which I have done via 'Paste Into'. This has worked fine but I have now lost words that do not fit into the shape. Is there a way of formatting this so that all of the text can be read but still maintains the shape?
I have attached an image to better explain what I am trying to do.
Any advice will be greatly appreciated! I've been struggling with this all day!
1.8K
Mentor , Mar 18, 2017 Mar 18, 2017
Convert your shape to Text Frame and fill with your text. No Paste Into required:
The Lounge Forum is not for technical help, please provide the name of the program you are using so your message may be moved to the correct program forum... A program would be Photoshop or Dreamweaver or Muse or InDesign or ???
Apologies, I thought I had written this but I obviously missed it. The program is InDesign.
Discussion successfully moved from The Lounge to InDesign.
Mentor ,
Mar 19, 2017 Mar 19, 2017
Ah brilliant thank you!
Is there a way of maintaining the two columns of text? I have done this but it has copied the text into one column like the below:
Select the frame, cmd+B and change number of columns.
You're a lifesaver, thank you!
Hi Lisa,
if you want gain flexibility I would work with two frames.
One for the text, that could be a rectangular text frame or even two threaded text frames plus the shape.
The two frames would be stacked:
Then you could wrap the text inside like that:
And you are able to optimize text composition by moving the text frame horizontally or changing the width of the frame:
Uwe
Instead of Paste into, copy the text, not the frame, and click with the text tool into the frame and paste it as text. The text will flow into this vector form.
