I know its a silly question to ask, but its something that I want to do if I can. So i have a rectangle pinned to the top that has a drop shadow to give it a floating effect. I was wanting to do that with the footer but Have it at a -45 degree angle. If I cant do this, its fine, I was just seeing if it was possible.
Is this what you are trying to do? You can't have - negative angles. If your top one is 45 degrees and you want the bottom to be opposite then subtract 45 from 360 --- this gives you a 315 degree for your bottom one.
Thank you!
No problem, good luck with your sites 😉
