There is an update available for Flash. I stopped using Flash after a previous update installed TrueKey and I had a difficult time getting rid of all its pieces.
I checked the current Licensing Agreement to see if it mentions installing Flash and find only this
"Use of some third-party materials included in the Software may be subject to other terms and conditions typically found in a separate license
agreement, a “Read Me” file located near such materials, or in the “Third Party Software Notices and/or Additional Terms and Conditions” found at
http://www.adobe.com/go/thirdparty".
- info at the thirdparty link doesn't mention Intel or TrueKey or True Key.
I do not want to install TrueKey - is there a way to install Flash without it?
[Moved from non-technical Lounge Forum to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
Thank you very much for the information. It's been very helpful. I've downloaded that file and ran it. It only installed Flash Player, no third party offerings.
One more question: Is this 32-bit or 64-bit Firefox? Please post a screenshot of the About Mozilla Firefox window.
I will forward this information to the online installer team to find out why it's not showing the third party offering.
<edit>
If you're still concerned, you can download the offline installer posted at the bottom of the Installation problems | Flash Player | Windows 7 and earlier
...Copy link to clipboard
Hi bmiller199
TurnKey is an optional third party offering and is not required. You can install Flash Player without installing TurnKey, or any other thrid party offering.
Great, thanks, Maria! How do I find out if I have JavaScript enabled? If I don't would I download it from javascript.com?
OK, apparently Firefox automatically enables Javascript. However, I do not see optional third party options in the middle frame at that link
Do you use any adblockers, such as ghostery or NoScript or similar? What operating system, including version, is this on?
Please post a screenshot of the page as it appears to you, including the address field showing the URL to the page.
I'm using Firefox 52.0.1. I use adblockers, but disabled them and restarted Firefox and got the same result.
Initially the link to flashplayer loads with Optional: (but no list of options) in the center frame, then changes to what you see above
Thank you for posting the screenshot. From my understanding, the 3rd party offering should be displaying. But the 'Total size' listed below the 'Install now' button indicates that only Flash Player will be installed using that file. I'm going to send this information to the online installer team, but would like to get some more information from you. Can you please provide the following:
Thank you in advance.
Maria
<edit>
If you're still concerned, you can download the offline installer posted at the bottom of the Installation problems | Flash Player | Windows 7 and earlier page in the 'Still having problems' section.
Maria
Thank you very much.
Maria
You're welcome, Maria - thanks for your help. I installed using that file and don't see any sign of TrueKey.
Bonnie
Thank you for confirming.
Maria
