Hi everybody!
I am just starting to use Muse and I have a question regarding the State button and different states.
What I am trying to achieve is fairly simple. I want that, when clicked on it, a box with some text in it changes its stroke color (this would be pressed state) as well as a rectangle outside of the box changing its color, therefore I need to use the State button component.
I have been able to make this behavior with the Rollover State or the Mousedown state, but I want it to stay like that, I don't want it to change to Normal as soon as I take my mouse away. An analogy would be a pressed button that acts like a toggle switch.
Any ideas on how to achieve this?
Thanks so much,
The active state will only work when page URL will be active, means the page would be active.
If you link rectangle to any page and then preview, the active state would work when you will click on it.
Because clicking the object will open the specific link that is associated with rectangle thus making it active.
It won't work without using any link.
Check this - Homepage
Hope this helps.
Ankush
This can only be achieved if used for triggering any menu or composition, However not on a plain button.
Ankush
Hope this helps.
Ankush
